MAF Values - REVO
Radek
70
Jonzy said:
open the csv file in notepad and copy the text into the reply box enclosed in
Code:
tags
Code:
,,RPM,Load,Inj. On Time,Mass Flow,,RPM,Mass Flow,Load,Ign. Timing,,,,,
,34.84,1520,69.9,9.84,22.94,35.14,1600,25.81,100.0,12.0,,,,,
,35.44,1680,82.0,10.25,28.67,35.74,1760,31.00,100.0,9.0,,,,,
,36.04,1800,91.7,11.48,34.64,36.34,1880,37.56,99.6,6.0,,,,,
,36.64,1960,101.5,12.71,39.61,36.94,2040,43.14,100.0,6.0,,,,,
,37.24,2160,110.5,13.94,45.94,37.54,2240,46.83,100.0,6.8,,,,,
,37.84,2320,110.5,13.94,48.72,38.14,2440,50.11,100.0,9.8,,,,,
,38.44,2520,109.0,13.94,51.19,38.74,2600,53.75,100.0,11.3,,,,,
,39.14,2720,106.8,13.53,56.86,39.44,2840,59.19,100.0,12.8,,,,,
,39.73,2920,109.0,13.53,61.78,40.03,3000,65.17,100.0,13.5,,,,,
,40.34,3120,110.5,13.94,66.08,40.65,3160,67.44,100.0,13.5,,,,,
,40.93,3280,109.8,13.94,69.31,41.24,3360,71.58,100.0,12.0,,,,,
,41.55,3480,109.0,13.94,73.25,41.84,3440,31.89,7.8,12.0,,,,,
Like so...
Code:
370.66	2440	48.9	5.74	24.69
371.06	2560	91	9.84	51.08
371.46	2720	94.7	9.43	49.53
371.86	2960	104.5	11.07	60.58
372.26	3120	110.5	11.89	69.69
372.66	3400	121.8	13.53	84.03
373.06	3720	143.6	16.81	104.69
373.46	4000	120.3	14.35	83.39
373.86	4320	169.9	20.09	157.72
374.26	4800	188	22.14	174.53
374.66	4920	175.2	20.5	165.83
375.06	5240	154.9	18.45	145.61
375.46	5440	158.6	18.86	169.36
375.86	5680	161.7	19.27	173.42
376.26	5960	156.4	18.45	176.42
Radek
70
Martyn said:
Have you done a run past 3480rpm yet mate?
No , had no time . Hope to have my car back from service for weekend , so I'll do road test .
But this export is completely unreadable :( I'm such a lame :censored: :cry:
Radek
70
Martyn said:
Like so...
Code:
C'mon ! how to ?
TimD
472
Right then guys and girls, here is another couple of logs using blocks 115 and 118.
Code:
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
Marker	STAMP	 /min	%	 mbar	 mbar
	46.35	2960	117.3	2450	1590
	46.85	3080	138.3	2430	1850
	47.35	3280	152.6	2410	2050
	47.84	3440	160.9	2400	2160
	48.35	3640	163.9	2400	2240
	48.85	3840	165.4	2410	2270
	49.35	4040	163.9	2420	2250
	49.84	4240	161.7	2410	2220
	50.35	4400	158.6	2380	2150
	50.85	4560	156.4	2340	2100
	51.35	4720	153.4	2260	2050
	51.86	4880	149.6	2200	1980
	52.35	5000	148.1	2150	1940
	52.85	5120	145.9	2140	1910
	53.36	5240	142.9	2090	1870
	53.86	5360	139.1	2070	1870
	54.35	5440	136.1	2060	1850
	54.85	5520	133.1	2040	1820
	55.36	5600	131.6	2000	1810
	Group A:	'118
		RPM	Temperature	Load	Absolute Pres.
	TIME
Marker	STAMP	 /min	°C	%	 mbar
	58.57	3080	48	99.2	1470
	59.07	3240	49	82.4	1860
	59.57	3400	50	83.9	2070
	60.06	3600	50	87.1	2200
	60.57	3760	51	86.3	2260
	61.07	3960	52	94.1	2250
	61.56	4120	54	98.4	2240
	62.06	4320	55	99.2	2190
	62.57	4480	57	99.2	2130
	63.07	4640	57	99.2	2080
	63.56	4800	59	99.2	2020
	64.06	4920	61	99.2	1990
	64.56	5080	62	99.2	1940
	64.97	5160	63	99.2	1920
	65.47	5280	63	99.2	1890
	65.98	5360	66	98.4	1870
	66.48	5480	66	99.2	1860
	66.96	5560	67	99.2	1840
I took a MAF reading as well but can't better 146g/s :(
What does the boost look like it's doing, good or bad news?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
looka at a glance like your boost is leaking & your wastegate is almost shut trying to make any boost.
TimD
472
ohh just what i wanted to hear :(
Any advice on what i need to do to sort it?
TimD
472
It had been sat idling for a few minutes while the laptop booted up and i got a connection to vag-com.
I wish i hadn't of bothered with it, just annoys me even more knowing there are problems that need money throwing at which i don't currently have :(
flashbsd
give the MAF a clean, worked for me, i pulled 130 with a stock ecu
