Low coolant warning light
acs87
hi guys,
looking for a bit of help. when i start my car first thing in the morning when it is really cold (this morning -5!) the low coolant warning light bleeps and flashes. if i turn the engine off and start again it usally doesn't come on again. i have checked the coolant level and it seems fine. its only happened a couple of times but just wondered if it was something to do with the cold weather, a common problem or just a faulty senser? car is a 05 fr tdi. cheers
alex
Mitchy
TTRS
Oct 12, 2004
2,310
have you tried a search as this is the most common question asked on here.
Discussed probably about 100 times a week for the past 5 years ;)
P.s...You either need to descale the prongs on the sensor in your expansion tank, or replace it. Not expensive, about £15 for a new tank, or 10-15 mins with a flat bladed screw driver cleaning the sensor :)
Jonny
slightly insane monkey
Jul 5, 2005
769
South Wales
I've had the same thing every morning for the past fortnight or so... it's annoying but a switch off / restart shuts it up :) As Mitchy says, either descale the sensor prongs or replace the bottle...
