Lots of error messages - Anyone seen this before?
goldeneye243
23
My car (2017 Ateca) is throwing up a lot of error messages -
Parkpilot not available
Error Start-Stop system
Error Stabilisation Control (ESC)
Error Hill hold assist
Front Assist Unavailable
Error Tyre Pressure loss Indicator
I tried a VCDS scan and it would not complete and hangs after about a minute or so, and displays this -
If I pause the scan before it crashes, I can clear the codes but they come straight back
Following some reading online, I swapped out the battery as that seemed to be a likely candidate, but the fault persists. I also couldn't see the battery module to recode the battery on VCDS (maybe I was looking in the wrong place!).
Is there anything else to look for, or is it time to get it booked into a garage?
Youtube clip here
graemebillo
122
29
liverpool
Might not be relevant
But on my 2017 cupra Leon not long after I picked it up it would randomly throw up loads of errors turning traction control start stop
Hill hold airbags etc.
Wierdly turned out to be one of the sensors on the wheel, possibly tire pressure monitor that wasn't fully connected and was loose enough that a bump or anything would disconnect it for a second.
Once restarted the car would be back to normal until the next time.
Might not be your issue directly but may help.
Sent from my XQ-AS72 using Tapatalk
cairus
1,310
470
It could be the contact block at the ignition lock. It is called S-contact.
would not be an unknown error in the VW Group
Reactions: goldeneye243
Seriously?
1,413
1,001
I'm not sure about SEAT, but on other marques those codes would be indicative of either battery low voltage or ABS sensor/reluctor ring issues, or even a faulty brake light switch
