Loggin suggestions
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
usuall things id look for are boost leaks = whistling under load ,
fresh oil , fuel n oil filters , maybe a additive like millers pro plus , good dielsel being used , try a tank or two of ultimate BP to flush it out
Nov 2, 2006
1,241
Annaghmore
bebo.com
Have listened for leaks, get a whistle, but it turbo at 1600-2200rpm area, usually hear it better when engine cold. Midway through service interval, but have a filter sitting, might change oil to see, use millers dsp4 and diesel seems good, but no way of knowing that. Nothing like BP ultimate etc.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Logs
Magine to get some logs done,
1st i done all 3 blocks one at a time, then done each block seprate.
Code:
038 906 019 J  		G000SG  1254
	Group A:	'003				Group B:	'007				Group C:	'011
		RPM	Mass Air / Rev.	Mass Air / Rev.	Duty Cycle		Temperature	Duty Cycle	Temperature	Temperature		RPM	Absolute Pres.	Absolute Pres.	Duty Cycle
	TIME					TIME					TIME
MARKER	STAMP	 /min	 mg/R	 mg/R	 %	STAMP	°C	 %	°C	°C	STAMP	 /min	 mbar	 mbar	 %
	0	1512	850	882	4.8	0.37	50.4	0	20.7	70.2	0.77	1659	2356	2020	51.4
	1.17	1785	850	1249.5	4.8	1.57	50.4	0	20.7	70.2	1.97	2058	2448	2560	65.3
	2.38	2205	850	1249.5	4.8	2.8	50.4	0	21.6	70.2	3.22	2499	2407	2560	73.3
	3.63	2646	850	1249.5	4.8	4.03	50.4	0	22.5	70.2	4.43	2940	2366	2560	82.1
	4.83	3066	850	1249.5	4.8	5.23	50.4	0	23.4	71.1	5.63	3276	2336	2560	90
	6.03	3381	850	1249.5	4.8	6.43	50.4	0	24.3	71.1	6.83	3570	2305	2560	94.4
	7.23	3654	850	1249.5	4.8	7.63	50.4	0	26.1	71.1	8.03	3843	2305	2397	88.9
	8.45	3948	850	1156.4	4.8	8.87	51.3	0	27	71.1	9.3	4137	2254	2183	88.1
	9.71	4221	850	1073.1	4.8	10.11	51.3	0	28.8	71.1	10.51	4368	2193	2122	82.9
	10.91	4431	850	1014.3	4.8	11.31	51.3	0	31.5	72	11.71	4578	2152	2081	82.9
	12.11	4620	850	975.1	4.8	12.53	51.3	0	33.3	72	12.93	4473	1102	1459	48.6
Big_daddy
Oct 20, 2006
3,930
Brummy
Code:
	Group A:	'003
	TIME
	0	1617	850	1019.2	4.8
	0.4	1743	850	1249.5	4.8
	0.8	1890	850	1249.5	4.8
	1.2	2037	850	1249.5	4.8
	1.6	2184	850	1249.5	4.8
	2	2331	850	1249.5	4.8
	2.42	2499	850	1249.5	4.8
	2.82	2646	850	1249.5	4.8
	3.22	2793	850	1249.5	4.8
	3.62	2961	850	1249.5	4.8
	4.02	3087	850	1215.2	4.8
	4.42	3234	850	1151.5	4.8
	4.82	3339	850	1141.7	4.8
	5.22	3465	850	1122.1	4.8
	5.62	3549	850	1112.3	4.8
	6.01	3654	850	1117.2	4.8
	6.4	3759	850	1107.4	4.8
	6.8	3864	850	1102.5	4.8
	7.2	3948	850	1107.4	4.8
	7.6	4053	850	1078	4.8
	8.02	4137	850	1063.3	4.8
	8.43	4221	850	1058.4	4.8
	8.83	4305	850	1058.4	4.8
	9.23	4368	850	1033.9	4.8
	9.63	4452	850	1024.1	4.8
	10.03	4515	850	1043.7	4.8
	10.43	4578	850	1033.9	4.8
	10.83	4599	850	735	4.8
	11.23	4431	850	612.5	4.8
	11.63	4200	850	563.5	4.8
	12.03	3948	850	548.8	4.8
	12.41	3696	850	563.5	4.8
	12.81	3444	755	578.2	4.8
	13.21	3255	525	622.3	4.8
	13.61	3066	320	646.8	4.8
	14.01	2898	250	641.9	4.8
	14.4	2772	250	612.5	4.8
	14.8	2646	250	627.2	4.8
	15.2	2541	250	602.7	4.8
	15.6	2436	250	597.8	4.8
	16	2331	245	588	4.8
	16.4	2226	245	583.1	4.8
	16.8	2205	240	573.3	4.8
	17.2	2142	240	563.5	4.8
	17.6	2058	240	563.5	4.8
	18	1953	240	553.7	84.5
	18.4	1848	245	352.8	84.5
	18.8	1701	250	382.2	84.5
	19.2	1554	250	377.3	84.5
	19.6	1428	250	357.7	84.1
	20	1344	250	328.3	84.5
	20.4	1092	250	328.3	84.5
	20.8	924	255	235.2	74.9
	21.2	882	260	254.8	66.9
	21.6	903	250	235.2	62.6
	22	903	250	249.9	59.4
	22.4	903	250	245	58.2
	22.8	903	250	254.8	57.8
	23.2	903	250	249.9	56.2
	23.6	903	250	259.7	58.2
	24	903	250	254.8	60.6
	24.4	903	250	230.3	62.6
	24.8	903	250	245	61
	25.2	903	250	254.8	60.2
	25.6	903	250	240.1	59.4
	26	903	250	245	59.4
	26.4	903	250	235.2	57.8
	26.8	903	250	230.3	58.6
	27.2	903	250	249.9	59
	27.6	903	250	220.5	59.8
	28	903	250	254.8	59.8
	28.4	903	250	264.6	60.2
	28.8	903	250	254.8	61.4
	29.21	903	250	240.1	60.6
	29.61	903	250	254.8	61.4
Big_daddy
Oct 20, 2006
3,930
Brummy
Code:
	Group A:	'007
	TIME
MARKER	STAMP	°C	 %	°C	°C
	0	62.1	0	31.5	85.5
	0.37	62.1	0	31.5	85.5
	0.79	62.1	0	31.5	85.5
	1.19	62.1	0	31.5	85.5
	1.59	62.1	0	31.5	85.5
	1.99	62.1	0	31.5	85.5
	2.39	62.1	0	31.5	85.5
	2.79	62.1	0	31.5	85.5
	3.19	62.1	0	31.5	85.5
	3.59	62.1	0	31.5	85.5
	3.99	62.1	0	31.5	85.5
	4.39	62.1	0	32.4	85.5
	4.79	62.1	0	32.4	85.5
	5.19	62.1	0	32.4	85.5
	5.59	62.1	0	32.4	85.5
	5.99	62.1	0	32.4	85.5
	6.39	62.1	0	33.3	85.5
	6.79	62.1	0	33.3	85.5
	7.19	62.1	0	33.3	85.5
	7.59	62.1	0	34.2	85.5
	7.99	63	0	34.2	85.5
	8.39	63	0	34.2	85.5
	8.8	63	0	35.1	85.5
	9.2	63	0	35.1	85.5
	9.6	63	0	35.1	85.5
	10	63	0	36	85.5
	10.4	63	0	36	85.5
	10.79	63	0	36	85.5
Big_daddy
Oct 20, 2006
3,930
Brummy
Code:
	Group A:	'011
	TIME
MARKER	STAMP	 /min	 mbar	 mbar	 %
	0.34	1596	2203	1703	19.9
	0.74	1701	2397	2009	51.4
	1.14	1827	2448	2254	55.8
	1.54	1995	2458	2213	54.2
	1.94	2121	2448	2336	62.2
	2.36	2289	2428	2438	63.4
	2.76	2436	2417	2479	65.7
	3.16	2583	2397	2499	65.7
	3.56	2730	2387	2448	64.9
	3.96	2877	2377	2387	64.1
	4.36	3003	2356	2366	65.3
	4.76	3150	2346	2356	66.5
	5.16	3276	2336	2346	67.3
	5.56	3381	2326	2336	66.5
	5.96	3507	2315	2315	66.9
	6.36	3633	2305	2295	65.7
	6.76	3717	2305	2285	66.1
	7.16	3822	2305	2285	65.3
	7.56	3927	2305	2275	64.9
	7.96	4011	2305	2254	63.4
	8.36	4095	2275	2254	64.9
	8.76	4200	2234	2234	64.1
	9.16	4263	2203	2213	65.7
	9.56	4326	2203	2193	66.1
	9.96	4410	2193	2173	64.5
	10.36	4494	2183	2162	63.8
	10.76	4557	2162	2142	61.4
	11.16	4599	2122	2132	61.4
	11.56	4683	2081	2111	63.4
	11.96	4725	2060	2091	63
	12.36	4641	1142	1969	48.6
	12.76	4620	1132	1612	48.6
	13.15	4389	1091	1520	48.6
TDI_luver
Newbie
Jul 11, 2006
115
Ireland
Googies,
43 mpg is the worst I have ever gotten over a 450 mile tank (overflowing to overflowing, so exact fuel volume measued accurately !) and that is moving swiftly over poor country roads and a bit of rush hour congestion also. Averaged 48 mpg last year on french motorways at steady 130 kph fully laden with aircon on. 35 mpg is awful unless you are driving like the stig continously...are you seeing a lot of black smoke at the rear end / soot on the rear bumper by any chance ? sounds like it's running rich and heavy fueling....so long as you dont have sticking brakes, soft tyres, any of the classic economy crushers.
Nov 2, 2006
1,241
Annaghmore
bebo.com
I dont drive like the stig, the odd blast yes but normal day to driving, same as yourself there. I did notice on a trailer there was a black area never had before on the front of the trailer, soot. hard to see if it smoking much while driving being low down and all that, i have a tail trim on and it puts any fumes past the bumper so cant tell there, trim does get black on inside.
Normal tyres, rear brakes are worn, fronts dont seembad and no noise from brakes while moving.
