Little question...
LMJ
Previously CEY_CLS :-)
May 4, 2009
1,789
Bangor, North Wales
Just wondering guys, is there anything stopping me from cutting 1 - 2" off my gearstick, then re-threading it with a thread cutter?... I just find it a bit tall that's all...it's just an aesthetic preference :p
*I have done a little search, nothing came up under Mk2 etc*
ather`s
EXEO Sport & mk2 IBIZA
Sep 7, 2008
2,059
mansfield, notts
would it be possible to take the shaft out of the car?? ive got my gaiter off and can see an alan key bolt. its about the only thing i havnt taken apart on the car so im abit unsure as to how it comes off!
LMJ
May 4, 2009
1,789
Bangor, North Wales
Think that allen key is to adjust it's sitting position, and adjust the plastic crown around it, where it hits against the other white plastic stopper, preventing it from hitting the right side, and preventing it from going into reverse on the left side. It's to do with that I think? Doesn't seem to come out when you loosen that.
LMJ
May 4, 2009
1,789
Bangor, North Wales
Oh dear! ha. Ok I'll bare that in mind! I think mine's tube you know? Not a solid "rod" as it were (don't know if you meant that?)
iCupra
thats so spooky, i was thinking the same thing today, ive had a look for short shift kits but cant find anything. i took the shifter out of my mk2 mr2 and put a shorter one in, only took about an hour or so.
while on the subject, do you know if its possible to change the gear linkage bushes easily? might tighten things up a little...
crossedmike
polo not threaded
replaced mine when i snapped my ibiza one :( but i find electrical tape on bar then put knob on works a treat
also on the gear links you can do the adjustment at the front i found on mine after i replaced both links : )
LMJ
May 4, 2009
1,789
Bangor, North Wales
It only crossed my mind today too, when I was emptying and scraping out nasty little chewing gums out of my bin! very spooky indeeed. :p Thanks crossedmike, I'm sure I'll find a way! :)
iCupra
polo not threaded
what adjustments can be made and how? :D
crossedmike
well mine went rreally slack and you can tighten them by loosenin the nut they are attatched to on the gear selector rod but is a pain because it can put your gears out of line :( so use a ruler mark where it was so if you do to much you can put it back but if not sounds like you might need new ones lik i did at 75 a piece :(
crossedmike
hahah becarefull lol if your like me and get pissed at old people hogging the fast lane on motorway doing 45mph i had to break hard still wasnt stpping so chnaged gear down so hard snapped it lol
LMJ
May 4, 2009
1,789
Bangor, North Wales
Well, I've just been out there now, and managed to cut 2" off the gear shaft. Wasn't too bad - a hacksaw went through it pretty well, took all of 5 mins to do it. Should be getting my GTi gearnkob tomorrow, stick it on and see how it looks. Looks nice with the standard one atm, much shorter anyway! :p
Will post a quick photo if anyone would like to see it :)
crossedmike
ye would like to have a look might bestarting something new here :)
LMJ
May 4, 2009
1,789
Bangor, North Wales
I'll take a pic of it with the GTi knob on it then :)... Probably tomorrow, if not - it'll be Saturday or a Monday, (as I don't ACTUALLY have it yet :p)
