Leon Cupra R25
sam-vr6
32
The VAG scene is good but numbers are limited. Not many people into quality modding.
Nowhere as big & developed as US or Europe.
POPOV
Newbie
Jun 25, 2005
581
Sweden
Ego picture post
Collection of images from the car magazine photo session months ago.
I thought it's fair if I at least once post some complete images of the car :)
y3m6UsYu6uExEiuWWBHdjLC83ArHZEN6JeCqSQdCOxggWipx_zce9qSD5V9ZR-QJwGfIe2uFFdVJd8bUuxFGr14-QIr2IC7b3JPYUtuW7dMTDJExowcoSRC_MQcIGRURF0sOSitDfAaaOZMflpQyc_KncFWOG7XJAzoiKxS-XQS4Zg
y3megcIkFdPCED49c54FwlUGieSTwN_v1vgV7A6S7zNlWvI5U0SC5Q8-3fEk7hTtktsbb3IYOFR9BivzBQy4e0-ySS-mwhRJ4S8B2IKFHTJHgOr4vVkUxdBozyve6dOI7gZDlZ0l0bJ-7NjEOKq5k_IDcJ3jT2veIFmIRIiS6E9hsI
y3mNlxo2fdfn0vPYXe47cuWGOLCc25iSl_VNIs4FimL-7udyBYXzEzOWnfoQTNuqR9gzI0wjxcS0Ku0iJIt0y-J7mJFyTpY47gwUhI3_EqDbcsfXveS9KyjCKmoXruIANG27xqFt2yrt43P2V7NgnhVSVptmA3Wkn-j2g1DkWC9W1I
y3msJwlGOmHkSEI-HEzZZ-jNLmVtNMbxr1MLWxoF-GqLsFVF79OEmAsJ5b5WLs7AbV2difbMfHj5nYbL7HjiFzb82Z6jFsdyRFS9gccssrzGaiRkl7HMO9ykwXA4h-5ga_V3YViFFAubcDcGk3g4vzbFbVHpMkcq4fRNLja3KmJbpY
y3m35kWHeSuzEKvSKLBOuyW8KRmvCDAIlVHEKUksrIVpMphTsoZaWwKEy8Xf-BFlSQqkhJW7d4J8uZdVYeceKD9GUWw6RBDMxew5xVsSwPGdZ1jbTy2EfSA9RMwaE5RFuhzXKVw-c4Lf-hBikmajfWY4-9V0LyPvJ1KyXTUKFpcC3g
y3m2sg-KgA9C9k4sajcZZr-mfTOTBGr-6tNoZppGg9OlvhqOOyBevfZlVjYT6PQvo28sEwRfjkRx97qZ_Eo1GBh5NO6po0sL3L3bv0CbOk8eS_eeWGYELGl1hxh2YApu5SDgoiaLcCWBjXLBIuCk6Yn3rJU493TruZMgyPftHlb8kI
y3mf8pjzcuIJrhuReund_jGjEgPC31OFViFDHVCqmzbiLirkqvWGU5qmRgHknZo8RqmakuWZOOctLte4zhphc5wZD8ilTanqaJWDg7uaCHqdv1L1KRsmXZQKrAn8swS4IeNCtu_Al7Y-pzlG4Oa8nKDBkVVXp6LL4_RNk7BB_ySHto
y3mdp0kJiZi7WmYJwo0Bw_qC0VvBQytRb-J-Jb40BdrOEM2auqj3rfvY0L0gTgXKDyXgRTEw4ar2TmD-rluZ4T5x1qMNiSkyNtLdF3gue_4llBjSmc42_uIMJYYOBSdSrAOa6b2V3yxiOCm_2gywFZvd6x-mk5i-8AkmwBlnTgvOzg
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
Hello Mr. Haldex
This weekend I connected the Haldex unit to the wiring loom of the car and checked if I could access the Haldex controller module.
All went on smooth and I got a nice greetings from my Haldex unit.
Next I'll service the Haldex unit, change oils, filter and pump.
y3ms7OjabvK3bF4lY9ylsR9c1Tc3HvYcrVABXqYsr9_1aqZj6YdFPm5FajrEK0FIfMvj_3WFxc4I26wZQ-0D428shb57N6tCrZ8km9xQ_LrvfbI5JS7ahJGlR_RhvOz1y6msi9G5X2GpwGJsPqaJXXGiNITJa7ZsdG3lcKlmukbOTY
:wave:
GhulamAfzal11
81
Wakefield
Absolutely beautiful car! Would love to do a shoot of it sometime, just two quick questions where did you get your tailights from and the yellow bar at the front of your car?
They look awesome would love to get a set for mine
POPOV
Newbie
Jun 25, 2005
581
Sweden
Thank you, happy you liked it.
Lights are from Dectane and the yellow bar is oem on the Cupra bumper, just painted in yellow by me.
POPOV
Newbie
Jun 25, 2005
581
Sweden
Haldex service
Time for an update I believe...
I'm all set for the AWD conversion but the shop that will assist me are not.
I would like to do the work myself but this conversion requires welding and cutting into the chassis that I rather let someone else do with experience.
Meanwhile I decided to service my Haldex, following bits where done this week.
y4mgSxzYhGciEdsdF2SOI66zgIn2UWcJzoyDV4YBMNnIBQrc_Vv1l8MJNbUH7RBihqzJK9mHKozVOYhJX4bCPl_aVxisWWXrwJN6eBDwANnCFJ7jyEShp8Qy1kMmggiMDHh9_K6Z_Ps6yknbh4lD-j_EcShM8cnbsI4pJVM8TzRlm_Z14hdwuBwu8vH51nS7pXVNT6z5vGbotvmWhhP3nmEww
  • New oil pump
  • New oil filter
  • New Haldex coupling oil
  • New Axle oil
  • New control unit gasket
Filter and pump where both in good shape as the Haldex I sourced was a low mileage unit.
Performing the service isn't difficult but needs some attention. The process has been described by others already, see the attached links for further details and insight.
http://www.ttforum.co.uk/forum/viewtopic.php?t=1496577&p=7874850
http://www.autofaultfinder.com/index-9.html
http://lz7w.blogspot.dk/2015/03/gen4-haldex-filter.html
:wave:
kevlaa
Altea Stylance / Arona FR Evo
Oct 12, 2010
266
s.wales
I just read your whole build and WoW I love your car!
Perfect in every way good job mate.
POPOV
Newbie
Jun 25, 2005
581
Sweden
Steering rack
Since the beginning of this swap I've been struggling to get my ABS working but I've not been bothered about it. I recently had to emergency brake on the highway and it resulted in flat tires and nearly an accident.
Once and for all I was determined to resolve this before I go driving again. I've been aware of what might be the issue as I can't calibrate my steering angle due to missing G85 steering angle sensor, without the calibration the ABS won't work.
My TTRS ECU expects to receive the steering angle input from the gen3 steering rack. My Leon was equipped with a gen2 steering rack that lacks the steering angle sensor as it's instead fitted behind the steering wheel.
So down the subframe went, the VAG engineer whom designed this should burn in hell :)
y4mQwD9dAweD-4AL4vJNFCHyXn4R503NNP0A7Lt1C41Jx93NAM0Jl80b6dgfwtCb8i149hNOuqkLECamsuWf5KULNjoNLekHgr6SFRpfL0y0r_hGzr4L5GshgiEQtOaDKPkeykww_mKuNs8VNvkyylHE_gndxoJUBpAHcb9FwtmKARsiMEGnMlBRL0wOAIWxAU4ydVPqf2DghrM_qkD5h630Q
Fortunately VAG designed the gen3 steering rack with the intention to make it fit on a gen2 equipped vehicle.
Some state that you can marry the TTRS ECU with an gen2 steering rack but I've really tried my best to find out how, even had an Audi tech look at it and we could not make it work.
As per the image you can see that the steering racks look identical, only one detail makes them apart. Spot the missing fitting point on the gen3!
y4mjRn8wtEhHNXAdfAWHLFR-9WPHUkVwuUwByCbXUtSU--SWTeKZWyCHgkK9s5mfe5sBnL5B7I41ZDc4Y8VMnTkEJamKkCVJTQjcD-kSzp6mh5Gkwg6LRfw6-AM1ZNVycuzYqQaZKfmOZkBUV2196DqfDXBcsdZ8UGibsebU0b0YFv2YLGbNfpmMgXk5pS6c2u2_Zpk92K8crZOY0DA31gDnQ
y4mUpwA4E16BXz3EqFcXX5BT9cOCigiBKFRuU9CDNYipJ8e9T1ewu7EHT1YZU3B5xxqvxqW7GTBH1u6Rh1rnfzHhhCU_Z8d9bZSpvn9powgOoYPWqo7KymFYIO78EqcE0HxnQICyLdzaMTTgzCCeociFtUvZH1xwJYvHweLOtePSFyGgTDksBjmJT6qyWzzrpW5r6XLShFvCOw_G8Oi7CE9oA
Quick check with VCDS now shows no trace of G85 steering angle errors and the steering rack basic settings options seems to be enabled.
I'll need to drive it to have it finally calibrated and confirmed but car is on jacks due to other ongoing works :D
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
AC delete
I've been searching for a way to remove my AC compressor pump, it saves ~4Kg and lessens the load on the drivetrain.
The EA888 (2.0TSI) AC delete bracket 06K145172 is a direct fit but requires some engineering to adapt the dual pulley from the AC compressor.
Without the oem AC compressor dual pulley design in place the alternator and water pump get disconnected from the drivetrain as per the image.
y4mMSyTUg8JR_g_sbGGZA2tfXkDqd64c0_cMY1RMxeC-4GqL7z96Y7j10qYIYRFk7dRvxnpOOIOe8iYykDICCHPUpYDtEuw1v6JqC0_kiH8Ln-gqwMkPI6D693e2TI0mzZRwK7bY9AMl4rJ3naZ9x85vrIjWMGrNoupZki6vNC-Ar43oYUMgca0P33nmbEqnCuzSp_Jzz2AL-rVQ4Q0U9VdiQ
y4mD1OhvjPOzVats0wmuKHebOSbdy3PI38pzhv3cP4XPYIqmjJFiNWuyeuFCPDClqSOUihjWKWs8icoZPuFfaTIMySB7LFY4K3vfI_rFxlUfxaf882Z6Xy1igtwTaIc1BkzywMD6uMQ1LqVj-pKuB4ZYK9ICDJU7LOfOt1BNHXUvO8gx09Ldh_EXogY1U-4Rn-gHbUOycvyg2iughr-LoVK8A
:wave:
POPOV
Newbie
Jun 25, 2005
581
Sweden
Phase II
Initially the AWD conversion should have been completed long ago but the garage that was supposed to assist me with a lift and welding seem to have lost interest.
A month ago I finally realized that there’s only one way, “DIY”, so I initiated the work on jacks. It’s hard work to do it this way as every task becomes more time demanding and difficult but I must say that It’s been a joy regardless.
The actual process of a AWD conversion has been done by others and well documented, summary of my work so far:
  • Cut out for secondary fuel pump access
  • Mounting of AWD fuel tank
  • Cut out of spare wheel, replaced by a flat aluminum plate and glued instead of welded
  • Assembly of rear aluminum subframe including the Haldex
y4mRGl4y7pUwgHpFZRVWUPm2BBBU44KWoiWrMipp8muk8VzSSYfTjXMfYCKl22XofdErHSXGkCF-i55EGr7jFCGOS_UMNtcJv-8iFu-B5ZwbnQgm8QG0Ok2eM3y7e-2dRPFDEZ-igh7W84zzmJLO3j-BdF_a9u61vS8METH1lO41dK1qjUAJJ43vk29Rm2fvtndFfBF4ykOdvQHex71Z4zuxA
y4mg5jqeH3RsK1waPw6DT8z_HcifeJr7gHxBHct0xbF0Fcq5gI4Iz231AMusoiNY2y5To22DtLMr6BgSHypRbEXh611-YPVO-ty488ktAwdSg4PdR_RLWhfg7c2D0rblVETd0G94UW-XywuBWrxye9MsIlFYf_QztJwDu2D9rS9j50GezEjgUG5_9jyVB5TCg-JRaYYf4dOdaJf3kWqBFX3xg
y4m0gVfWK0I6-hjjzsNKCU1Y4xIrCLzGXLvy9cNA_IN89q3Kw0_gkKoefdYVTNb2_5wwsWwTujw2LpXD82M_TrPI7u8wJa-bRP3Kh-w8Loxt3WB5nMTtXovgNLU7I3mohshdf-1ikyGoY_STUOCqsmj50hGWbpnOW0LlvGMfqkt3xKc9XDJ9JnkwcsW5tR0yEy4TmGKkKoQeNx8uGeN-G91pw
y4mFQr7OeV1w57_Hl3fB3IaGkGzuUf_Ef7PpEtoniQ98yK-TWM3QnQNEhrWKlJUkJ4HOkWDmCBxkPnDQdtanRbArAYrlxe3CO0TOqBxkMsBZ8DqhQJtzJ1xv5v1KXiJAgu_oJIFsUXS1sy8u_K3rO7RxK-EcgaaKZMT6OcG-7bmyEtf67IASYsiqTVHsaBey82nNApQHYblTuSKzMyfZ6a5uw
y4mvUYZpEm4Mfrs4zHnLPiLyMOfeo4RjLEqdVdVMFL19-BrIhUEVWFOdPa6drjOzfUPltySaJhSB4HqsutROXJPZGFlXp2m4bWxFZPwJ_pa1k7iuX916DFxdwRlelojO9eSr6I4yR5Yfbg6-hPtvzsCQVPMf4_N8k9ghtgMkwqXJ4729Rwh3LZn2LoW1TSfbFADPhBTqahj8kHZ1FRa3fCKMg
y4mwvJ9EMImJ8qVgLwvulo071vcHWQkgcxR0OWmCkFeRBu_-DIZpecaFmLEUQZiVSIdQ3NjmBZhbhEDxH-Mlw0lGucYh0-uqpuyNm0GA1t5P0B4VsATI4TMBzy5IZBj_IrPP8rhY7YvQiQm3nnf20mw1oShFDo0VwBbfvfScDF01Igt5i-anqv_YjlwnUDifGVmVL1L51KVc_I8B286_U8fYw
:wave:
