ok I am back with updates and it is summer time so lots of time to work on the project since I have time off from university
I will start with the rear brakes as you can see I refurbished them and got theme powder coated black to fit the fronts
disassembling is easy only need to attach air pressure hose to the brake fluid inlet in the caliper give some pressure and the pistons pop out I do advise to install a wood block in between the pistons so they don't go flying and you don't hurt your self's. installation is easy as well just lobe everything up with brake fluid and install the dost boots into the pistons before installing them because if they get pushed in by mistake which they will you will need to attach the caliper back up to air pressure to get the piston back out
if anyone is interested I can elaborate more on the procedure of refurbishing the calipers
the install not much to say about it I just removed the old calipers and installed the new ones using 312mm discs I'm using solid front discs for now until I finish working on the floating discs and hats I am getting CNC'd
bad pictures in the install because I forgot my camera on my way to my shop so Iphone pictures for now I will get better pictures when I get around to giving the car a wash
install (more pictures soon!!!)
