OK some progress
First of all ill start with a BBK project I have been working on for the rear of the car to fix the bias of the front braking power
Not that it’s too bad but considering I’m running a set of 365mm 8 pot Brembo's in front I though it couldn’t heart to upgrade the rear
So hear you go, I got a set of custom brackets cut up to fit a set of Cayenne 4 pot Brembo calipers and a set of Brembo parking brake calipers
Discs are 312mm just waiting for a set of braded lines specially made for the swap that are on the way and the set of Brembo parking calipers
I am going to get the cayenne calipers powder coated in black to match the front brakes as well before I get them fitted
Brakets
Cayenne Brembo 4 pot caliper
And now to real progress a few parts came in for the Exhaust system I’m working on so next week I’m going to get it build
Custom made 3” all the way with all V-band connections and all Stainless Steel 304
You can see the Stainless Steel 304 V-bands turbo flange and CO2 bungs and also one set of 4” V-band to conect the two parts of the DP and two 4” to 3” transaction that are intended for the 4” DP I will be building when I finally get the intended turbo
I will be back next week with pics from the exhaust manufacturing and install
I'm dying to see how it goes with these brakes at the rear.
and a video to hear the sound of the exhaust line?
When will it be done?
