Leon Cupra 100-200 time?
juanfran_mr
7
7
So here is my latest 100-200kph with my new set up, new dyno figures are 391bhp 400ftlbs torque ish. 3 inch cat back added over the original exhaust and map tweak. This is before and after results of the dyno also aswel as the new dragy times. Cupra 280 5 door pan roof dsg.
Hi
I'm impressed with those records
In Spain, Leon Cupra Stage 2 usually do between 9 and 9.5 seconds in the 100 - 200
How is it possible that you achieved those results?
Congratulations
Zer0
522
244
My best 4 runs were between 11.05-11.28 with Dragy so pretty consistant, done 9 runs in total. Will of course be nowhere as fast as a lighter fwd but I'm happy with that. Completely stock apart from JB4. 2 kiddie seats, ST 4drive DSG7, winter wheels.
Mr Statistics 1990
28
15
Hi
Congratulations
Hi, it was in freezing conditions at 2 degrees with my back seats out. My car consistently does 8.6-8.8 full weight. My PB full weight is 8.55, however in Spain the temps are a lot warmer, once the weather gets warmer here I’m sure I will do 9 seconds 100/200.
Zer0
522
244
3.85s 100-150 km/h
10.12s 100-200 km/h
Car will also do a Dragy verified 70-120 km/h in 3.00s and 30-70 mph in 3.39s, proper quick.
Cupra ST 4Drive DSG 7. 3/4 tank of fuel. Couple of kiddy seats in the back.
JB4 custom map 6, RON 98 + E85, mix is E25. Also have the full MST intake which means large turbo inlet, larger hose and air filter.
Kirky
Copper Cupra Advocate
Apr 10, 2019
1,042
497
3.85s 100-150 km/h
10.12s 100-200 km/h
Very quick.
I'm getting a JB4 when/if I get back to the UK in July. Would you assist me setting up a custom map if I need help?
coiloverspl
26
49
CUPRA 5F Hatch with GPF
OEM intake improved
Fuel tank full on 80%
JB4 Map6
Just one pass, i think with lighter summer wheels and lower level in tank should be better.
Reactions: Zer0
CupraRacer
47
37
My tuner (MR Chiptech) installed an upgraded IS38 (stabilized) turbo.
Now the Leon Cupra is a bit faster:
Some 100 - 200 times ...
Mr Statistics 1990
28
15
Do you get the best times letting it rev out fully and let the DSG do the job?
Hi mate, no I do it in manual mode and normally shift around 6.5k or just slightly over, as the is38 dies off after that, but as long as you shift back into your peak torque.. I study’d my dyno graph where my peak power was etc for optimal shifting points when drag. I’m not sure what power I am at the moment need to get another power run after changing intake to R600 as my shifting points seem to have changed a little.
Reactions: Zer0
Zer0
522
244
Yeah looked like you shifted manually from the video. I shift at around 6.2k myself, think I need to let it rev slightly longer.
It's a fine line between hitting the power band on the next gear and not running out of steam on the top end in the current gear. :)
Mr Statistics 1990
28
15
I’ve just noticed you have the ST Cupra with jb4 and intake only?! If so then 10.1 is a really good time! My friend has the MST intake and jb4 map 6 on his cupra ST 4wd like yours and best he has done so far is 10.7, yeah it’s spot on what you say about a fine line, you gotta practice with them shift points as it makes such a difference, if I shift at 6.2k compared to 6.5k it can make it half a second slower sometime lol or .3 slower etc.
Zer0
522
244
Yes I'm real happy about the performance considering those are the only mods I have :) Would be nice to dip into the high 9s, think it should be possible once I find my best shift points.
Mr Statistics 1990
28
15
9’s would be an amazing achievement with them mods! Specially with the weight of the car, when I was stage 1 with pikey R600 I did 9.5-9.8 100-200kph and mines the hatchback! So if you can achieve a 9 with the ST with jb4 and intake then that’s fantastic! Your doing the same times as a stock facelift rs3 at 10.1
Reactions: Zer0
