Leon Boost Gauges | Oil Pressure etc - Which Gauge is the best match???
StokieShinobi
Cupra R Potter
easy...Defi BF
This one is at 90 spot on???????
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
mine varies a lot depending on driving conditions. 75degrees on a normal drive, gets up to 95degrees just sat in traffic with no air flow, and up 120degrees ish when driven hard.
ThackersLCR
141
Blackpool
Ok here's my Auto Gauge I sprayed up last night in the shed!
I used masking tape,worked ok I thought!!
Primer:-
Matt Black:-
Finished Dial:-
Good effort that mate! Have you just gone for the single pod? Iv just put my oil temp gauge in, but im unsure of the correct ignition wire for the posative to the guage (not the lights). Any ideas? Taa
CupraR_Lad
515
Herefordshire
Thank's buddy! I'm just in the middle of masking the Oil Temp Gauge now! You got Auto Gauge's?? If so what oil gauge do you have?
ThackersLCR
141
Blackpool
Iv got the same as you mate! Cheap and cheerful! :D Happy days!
Im in the process of changing the internal bulbs for a red one on my knackard boost guage, well trying anyway!
I was in two minds if it was pressure or temperature, i went for temp in the end with the two pod a pillar from nomad.
CupraR_Lad
515
Herefordshire
There are two different Oil Temp Gauge's Which one do you have!! Yeah I sent my nomad pillar back yesterday,because I wasn't happy with it! Should have the new one soon!!!
StokieShinobi
Cupra R Potter
There is one behind the headlight switch - thats where I put mine. Its on the big block connector (cant remember the colour now sorry) - get a multimeter on it thats how I found it - scotch lock off that :)
CupraR_Lad
515
Herefordshire
Very nice :) looks good in matt black - you did well not getting paint all over the face! Good effort :clap:
Thank's chap! :p I drew a circle on a bit of masking tape!cut it out! then cut the tap into little pieces and stuck then on one at a time to fill the circle in! If you understand what I'm on about!! :p
Then took the masking take off! and use a cocktail stick around the edge to remove some of the paint and make it a nice circle! I'm happy,just waiting for the Oil Temp gauge to finish drying then I will be doing that one!!!! :D
ThackersLCR
141
Blackpool
Its all in and working, just iv used the same +ve supply from the dimmer switch so when i dim the lights, the needle drops. Just need another supply as well as using this for my yellow wire on the gauge, so i dont have to keep changing the backlight colour everytime i start her.
BoomhaueR
Wanna go fasterrrR
Oct 9, 2008
810
Exeter, Devon
I did the same thing last week...works a treat! Looks like you've done a good job too.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
You need a perm 12v there is one on the fuseboard, pop the cover of the back and it's along the top, again use a tester to be 100%.
