Ordered a 10.6 cable from DHgate. Tried to install the software off the mini CD, but apparently it has a virus/Trojan in it. So I downloaded a non-virus version from elsewhere. Also have the 704 version from the bay. With either version when doing the USB test, I keep getting "cable is not plugged into car".
Can someone explain the best procedure I should be following? Is the car meant to be running or just half ignition? Do I plug the cable into the car first then the laptop? Is there a sequence to follow or does the sequence not matter.
Also how hard am I to push when plugging into the car. It just feels a bit loose.
Hosts file (3 addresses) was edited before any software etc was installed. I have tried changing clock back, this stops both VCD versions complaining about being out of date. But still cant get past the test part.
Anyone have any suggestions?
My 805 software has stopped working too, uninstalling and reinstalling does nothing, says the software is out of date and no cable is connected suppose you get what you pay for!!
My version says that but i just change the date on my computer it works fine.
Aaaah yes, guess I don't use it enough to have remembered that, cheers for the reminderWhat date do you have to roll it back to?
Any link to where I can pickup the software?
Ignore my earlier post as it is now working with the software that came on the CD with the cable. I think the virus was a false positive (hope so). Setting date to Sept 2010 gets rid of out of date message. But having correct date does not seem to stop mine working.
Is your cable a VAG106 / 10.6 version? If so PM me your email and I will forward my copy its 12Mb from the CD or email u a link.
Not sure if it helps anyone out but I've done a lot of reading on this thread and others for the best cable and ended up ordering this one from DHGate..
http://www.dhgate.com/vag-com-106-3...-10-6/p_ff80808130e5a5220130f30182551688.html
Seems to be the latest cable and version of VCDS so hoping it lets me fix my alarming problems......I'll get me coat...
I was going to stump up for one of these:-
http://www.vag-diagnostics.com/sales.html
Any reason why I shouldn't anyone??
