I've found this. What do you guys think? Tempted to get one!
Apparently won't be able to change setings with it according to other forumers.
Doh!
I wondered how I found it!
So it won't work? All I want to do is set the alarm beep up, set the lights to come on when I unlock it and weight the steering a bit more. Oh and to check faults.
Can't justify putting down 250 notes on a cable at the minute!
I don't know, I think ppl might be assuming it doesn't cause it's cheap... I'm the same positon and have the same needs as you mate. I want the alarm chirp and lights to come one. I had it on my mk5 golf I miss it. Also was thinking about steering weight, i noticed it felt light compared to past cars.
The company is from singapore so I imagine they won't be a a scam seller, they're pretty tough in singapore on law and a proud nation. So I imagine the product does what it says but might take a while to arrive.
did anyone find a cheaper vag com cable. I really need to code my sat nav in, after taking it to the dealer today they have said there a lot of error showing up due to the sat nav.
Me and the dealers don't really get on to put it's in a nice way. After refusing to fix a part on my last car and basically lying to me I got in touch with trading standards.... As there are no other seat dealers anywhere I'm stuck now And they will just charge the earth to do it
Guys,
I bought the one that Knight recommended earlier in this topic.
It works great, however, there are a few things to note:
- Version 805.0, supplied with the cable, did not work. I had to use 704.1 even though I bought an '805 Cable'. I got 704 from a well known site featuring a ship!
- Turn off your internet or add an entry to your hosts file to point the rosstech website to localhost. Ross Tech can send a signal to disable any 3rd party cables you see.
- The '805 cable' is the most stable, so if you dont buy the one in this topic make sure it says its for version 805.
Any questions let me know
myself and Sean Corky bought a China Special VCDS Cable and it works perfectly and performs all that 811.2 can do
Cost around £40-50 IIRC i carnt remember the link tho so maybe Sean can help
so basically if i buy this cable above obtain the correct vag com software i will be able to code in the sat nav and also play around with the some of the other settings on the car too?
