dawnyellus
Hi
Could anyone help me, I've got a leak coming from a pipe on the right hand side of my passenger footwell. It seems to be connected to the air con and blowers. It's definately not the door seals, and I've checked the pollen filter and cover, which looked a little warped but not so much that it could let in so much water. I have covered the top area of the bonnet to see if that helps but it seems to make the water leak into the drivers footwell. I really don't want to spend a fortune in the garage diagnosing a simple problem so any advice is welcome.
Dawny
sounds like the heating matrix it happened to a bloke at work can be repaired but get it looked at ASAP before all the water drains out into the footwell.
Thanks guys will do! Too late on the carpet front though I'm afraid the carpet has been wet and dried already.
