waterleaks
hi, dont know how to pm you, any ideas as i am pleased to help1 you will not get the tissue wet as water runs straight behind carpet/sounddeadening above pedals and down onto floor. scuttle just pulls off after removing wipers, seal is attached to this.
thanks john:D
So the hole in your picture is quite easy to get to once you remove the wipers and scuttle panel? What did you use to fill the hole, and how big roughly would you say it was?
Was it easy to remove the wipers as well?
I think to PM someone you would just click on their name, but as I don't have 10 posts yet I can't try it!
Cheers, Andy.
waterleak by pedals
Hi, had to use a small puller to remove wipers the first time,but came off alright after that. hole was about 10mm diameter but dont make my mistake-i missed it the first time due to dust hiding it, a airline exposed it. used sicoflex to fill hole and pressed it in, been ok since just took a day to put inside back in
