L.E.D sidelights that work...?
ross27
Mazda 3 MPS
Mar 22, 2009
363
Glasgow
Yeah, i will do. Hopefully i get them on Tuesday, and if i dont have the correct resistors at my house, i will need to go buy them. Off on holiday on Thursday.
Has it blow your bulbs? Or is the car just not accepting them?
I had to do a similar thing in my old Civic. I changed the front seats to ones without airbags, so i had to put in a resistor in place of the old airbag, fooling the airbag ecu as to think it is still there.
White_Lady_170
Dirty Derv
Jan 20, 2009
493
N. Ireland
nah L.E.D's still workin 100% and will stay on for as long as you like if you dont turn the ignition on...
soon as the car is running they will stay on for roughly 1min then they go out and the bulb fail light on the dash comes on.
i have resistors here that are supposed to do the job, they are off carmodshop online. i tried one and the L.E.D isnt even interested when it is in place. must be the wrong resistence or something...
ross27
Mazda 3 MPS
Mar 22, 2009
363
Glasgow
LED's will only light up when the polarity is correct. If you have them the wrong way around, they will not light up, atall.
All i am going to do is cut the resistors into the wire before the bulb, then put heat shrink cable over the solder joins and resistor. Hopefully it will do the job.
Should receive the side lights tomorrow. They look great in your photo on the previous page!!
Currently i have them blue painted filament bulbs that quite a few people have, they are a good colour match for my HID's at night, but they are pathetic for brightness.
Do you have a multimeter?
If so, check the resistance going across, the standard side light bulb, check the resistance of the LED bulb.
White_Lady_170
Dirty Derv
Jan 20, 2009
493
N. Ireland
yeah the sidelights im running are terrible for brightness and are a bit too blue for my liking...
don't have a multimeter, so im relying on you to be able to work out some sort of fix! :D keep me posted
chrisboyle999
MFD3 for sale, inbox me.
Nov 28, 2006
1,838
Geordieland
power=amps x volts_______bulb is 5W=? x 12v_______so current draw is 2.4A.
resistance=volts/amps_____so, ?=12v/2.4A__________therefore resistance is 5ohms.
the resistor and LED (which should be negligable) should be 5ohms. if you cant get a reading through the LED turn the lamp or the leads around.
all this is in theory or course, in reality there may be slight differences.
chrisboyle999
Nov 28, 2006
1,838
Geordieland
^^^^^^^^Ohms law :D
correctamundo. old georg still to be proved wrong.
chrisboyle999
Nov 28, 2006
1,838
Geordieland
the resistors i have at home are 25w resistors...? what is that compared to ohms?lol sorry... i wasnt bad at physics but ive forgot the most of it now!
what colour are the bands on the resistor?
they should be; brown-brown-red-gold (possibly silver or brown or red or missing altogether, its the first 3 that are most important)
power is measured in W so i dont know what you have your hands on.
ross27
Mazda 3 MPS
Mar 22, 2009
363
Glasgow
I get a reading of 2.7 Ohms across the standard sidelight bulbs.
And for refference, the brown sidelight wire is the Earth/Negative, leaving the Purple (Yellow stripe) to be the Positive.
Had to find this out because i was getting two different readings across the LED, so i had to find out which way it connected up.
Edit:
Having major difficulties with this! lol
I am not getting an easy figure from my Multi meter. As i am not very electrically minded, ive got my self in a puzzle.
Mainly due to the settings on my multimeter.
When readin Ohms it can either be at
200
2000
20k
200k
2000k
The results for the standard sidelights are:
200 - 02.7 Ohms
2000 - 002
20k - 000
200k - 0.00
2000k - 00.0
Now to me that makes sense. Now the results for the LED bulbs:
200 - Blank Screen
2000 - Blank Screen
20k - 7.94
200k - 29.2
2000k - 206
Now i cannot think how to interpret that :s!!
And for refference, the LEDs them self have a power consumption of 130ma
White_Lady_170
Dirty Derv
Jan 20, 2009
493
N. Ireland
Poverty
lads, someone has already done all the hard work in figuring out what l.e.d's and what size resistor is required. Search for h8t w8p's post (username spelling might be wrong)
OLDOILER
1,292
Wiltshire, UK
You do need the type that disapate heat and mounted on metal body work{ally body resistors 2.2 ohm/25w ?}not the wire wound shown in the pictures so mounting them in line may cause a fire risk. I have used a very simple 501 bulb holder and bulb built inline which works fine over the last 18months. ..................
