K03s turbo outlet size.
paulos44
537
Warwickshire
Could someone tell me the diameter of the outlet on my K03s turbo please and whether normal silicone hose is used to connect to this ? I am getting the bits together gradually to have a go at a custom FMIC install with 2.5 inch pipe throughout,which has been recommended. I have already decided on something like a 690mm x 175mm x 64mm intercooler which will hopefully will be narrow enough to hang off the bottom of the crash bar.
paulos44
537
Warwickshire
Well I am surprised it's that small...been told by a respected mapping company to use 2.5 pipe throughout for a Stage 2 but I can't see any advantage in doing that on the hotside of the intercooler. I would have thought it would just increase lag....bigger volume of pipe to fill. Is it straight off the turbo outlet with silicone then ?
Sent from my XT1039 using Tapatalk
spudboy6
721
114
Swindon
The silenced ko3s reduces a lot through the silencer , a non silenced k03s has a lot larger outlet pipe ,
Yea straight off the turbo with silicone to the charge pipe ,
I don't know a great deal about pipe work sizes and the affect it has so can't comment on that
spudboy6
721
114
Swindon
There's two types of ko3s turbo , one has the silencer built in to the turbo and this then reduces the outlet size , earlier ko3s have no silencer on them
This will only matter between your turbo and charge pipe work , after this use 2.5" all the way round
paulos44
537
Warwickshire
I find it hard to get my head round the fact that silicone will be able to withstand the heat coming from the turbo..........
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
I have my sfs oversized tip on my car, had it on now since April and I've had no bother, I do thrash the arse of her now and again, the silicon can withstand some heat so I wouldn't worry to much
spudboy6
721
114
Swindon
Silicone can with stand a lot of heat. What do you think the standard one is made of ? A type of silicone / rubber braid . also it gets put in a heat shield jacket to help protect it
paulos44
537
Warwickshire
I was on about the what must be very hot air being blown out of the turbo into the engine.....
paulos44
537
Warwickshire
Thanks for the info...i see your Tolly is making some good power spudboy....what size roughly is your intercooler if you dont mind divulging ?
spudboy6
721
114
Swindon
I'm running a pretty big cooler I had to hack away at my bumper big time to get it behind (so I now run Cupra R bumper )
600x300x76 ( I've got reducers from 3" down to 2.5" pipe work after cooler )
Toyo sports type b cooler
Also fitted Cupra R inlet manifold so it switches the throttle body over to the other side of the bay and makes routing pipe work a lot easier as don't have to go over gearbox
paulos44
537
Warwickshire
Hmmmm......impressed.
I am gonna attempt to get the bumper off mine at the weekend to see if i have the space to fix the size i mentioned in my first post to the bottom of the crashbar. I really want to keep things original if i can and will be happy if i can get 240ish+ bhp with a smaller intercooler.
paulos44
537
Warwickshire
Well got the sfs tip,milltek not res with Toyosports 2.5 D/P and sports cat, full set of new Beru coil packs, JETEX with shield. In 2 minds whether to do the 75/249 delete before the remap...
spudboy6
721
114
Swindon
It's good to delete them as they can hide tiny vac leaks which cost you precious bhp. Once you are remapped message me let me know what power you've made
