k03s hybrid or bigger
mikey_b
322
Manchester
Hi thinking to upgrade my turbo was wondering if theres a direct bolt on turbo other than a hybrid k03s?
anyone selling a used k03s hybrid?;)
thanks
Mikey
jamfull
157
I have badger5 ko3 hybrid K300 I think ,mine makes 289 bhp . Will make more with WMI.
Toyo intercooler, 550 injectors, 3 inch custom made Badger5 TIP, Sach paddle Luk clutch set up.
If you wan to keep OEM look its perfect.
If i was to do it again i would go for a straight ko4 hybrid swap , you will have to change water and oil lines and manifold for this but there is more scope for power if you add wmi.
mikey_b
322
Manchester
ive been offered a s3 k04 turbo, manifold, charge pipe, oil and water lines and injectors for £450 or
a jabba sport ihi manifold with a vf34 (needs rebuild) oil and water line and a dwn pipe (will need modifying) for £220
witch one shall i go with?
Dec 25, 2009
1,531
Id try stay with KO3 hybrid, quicker spool and less hassle with DP etc keeping OEM look
mikey_b
322
Manchester
Where can I get a used hybrid from then...not looking to buy new...I know im a cheap skate haha gotta look for deal/bargin lol
mikey_b
322
Manchester
Where can I get a used hybrid from then...not looking to buy new...I know im a cheap skate haa gotta find a bargin
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
good luck in finding a 2nd hand one. If one does appear then I wouldn't be too sure about it. What sort of life has it had? What miles has it done?
If it brakes , what is the cost of getting it re built?
Have a word with bill ( badger 5 ) see what he would charge for one .
A saying that I will stick too...... Buy cheap buy twice. Wouldn't go cheap on something like a turbo. If you insist on doing so , then there is some lovely copies on eBay ( china / USA ) . I wouldn't touch them with a barge poll. Save the extra bud.
Ronin225
4,652
22
Worcester
I was under the impression vf34 'chocolate turbos' weren't rebuildable so if its knackered you'll need a new one
Not sure if the cost of upgrading to a k04 is worth it for the little power gain you'll get
As for trying to get cheap second hand stuff, i'd want to know the history of certain parts well before i'd even think of exchanging a penny
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
Would a k04-001 with correct pipes etc not produce a very similar power to a Lcr k04. Thinking a k03 and k03s produces similar power. Would this not be the same case ?
Totally agree with 2 nd hand stuff. Unless I knew everything about it with paper work to show it then its a no no from me .
ozaudio
387
north west
Q: What is a k04-001?
Quote, originally posted by »
It is a turbo that is capable of producing slightly more power than a k03s (~10-20whp). It is made by Borg-Warner and is almost exactly the same as the k03s externally.
Q: What do I absolutely need to make one bolt on to my 1.8T?
Unlike the k04-02X, the external dimensions, oil/coolant line fittings/etc. are all the same on the k04-001 and it will bolt right in place of your k03s...with one exception. The turbo inlet is a bit different, so you must upgrade to a silicone TIP (any k03s silicone TIP will work). Others have reported modifying the k03s TIP to work, but if you want to avoid the hassle, the silicone TIP will bolt right on.
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
So are we saying but a ko4-02x , change tip and that's it? Similar power to a Lcr ?
mikey_b
322
Manchester
From having a evo pushing around 380bhp/380ft lbs and the leon feels a tad slow...I dont want that sort of power but enough to make me smile
cupraslayer
I want more bhp
Feb 8, 2008
1,543
northampton
Sorry . Think I've mis read your answer. K04- 001 with changed tip will go straight on ? Producing 10-20 bhp more ?
Would this need to be remapped tho to suit? Eg - I have revo stage 1 . Changing turbo to that would that req a custom map
ozaudio
387
north west
yes, but you need to change the map a little also
Q: What about software?
You can run a tweaked k03s file, REVO stg2, GIAC k04-001 SW, APR k04 file, or Uni stg2+ (i'm not sure if there's a eurodyne specific file).
its all here
http://forums.vwvortex.com/showthre...-(click-here-before-making-another-k04-thread
I have a stage 2 so if I was to find a k4 001 it would bolt strange on according to that thread, I think if I found one for £300 or under it would be worth it for 20 wheel BHP
N/A cars spend over a £1000 to get 20 bhp lol
