James' LCR - 2008cc Stroker HTA GT3071r! - Tuned @ Badger5
Ronin225
4,652
22
Worcester
Its still there i've just been on it and found this
(20) 038103603M
oil sump with opening for oil level sensor
/ AGU,AQA,AJQ, ARZ,AUM,APP, AUQ,APY,AUL
Give me 5 and i'll pop to the shed to check part number
Dani_b19
301
Ive got an s3 and im 99.9% sure the apy and bam sumps are the same, both have the same level sensor.
Ronin225
4,652
22
Worcester
3 sumps listed, 2 with oil level sensor one without
Part number on sump i have is 038 103 603 L (most others end in M) there is no info on what else is different between the two
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Well sump is off!! Actually A LOT easier than I thought it was going to be, a long wobble bar, a 10mm socket and ratchet is all I needed to take it off, will probably need a 5mm ball ended Allen key in order to reinsert the bolts straight.
Seems a shame to throw away such a clean sump!
The offending plug hole.
Going to need to clearance the new sump for the arp studs
A cheeky shot of the engine
And finally the offending ECS item!!!!
Just need my new sump now.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
I've taken the plunge! Ordered myself a baffled sump and OEM sealant from AKS tuning. Should be here tomorrow.
Really toying with the idea of making this a track toy as well as a fast road car so a baffled sump seemed like the right thing to do.
I don't think it's likely to see the track this year, want to get myself a lighter set of alloys and some semi slick tyres on them before I think about putting it on the track, also want to get a decent oil cooler and Apexi AVC-R on there as well as some 2 piece discs before putting it through its paces on the track.
These are all things to do over the winter I think so it can be ready for some track action next year. :)
IbizaAlex
AKS tuning
May 11, 2008
532
Bedford
On its way James. All clearanced for the flywheel and the ARP main studs ;)
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
New sump turned up yesterday!
Took a couple of hours to get it all on properly and filled with oil etc. Pleased to say no visible leaks but will be keeping an eye on it for a week or two.
One step closer to some track action.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
There's a Brands Hatch trackday around September I think I was told, £150 open pit lane all day... Not sessions either, go out as and when...
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
Such an idiot!!
:cry:
Why am I such a penis! Was doing some general maintenance work on the car at the weekend topping up fluids etc. Came to topping the gearbox oil and me being a lazy decided to just lift the top of the gearbox selector fork and fill from there to put an extra .5-1.0L in as the top gears can sometimes get starved of oil and managed to pull the whole gear selector fork right out the top of the box!!!! This means, (unless I am mistaken) I've got to take the whole box off the car, strip it all down (AGAIN!!!!) and rebuild it with the selector fork in the right place.
I have tried reinserting the gear selector back in the top of the gearbox but don't want to force it into the wrong place and do damage to the gears etc!
*sigh* I know what I'm doing this weekend.
Anyone got any tips for removing the gearbox?
