how would you propose adding a bead to the pipes (stainless) or ally
I have a bead roller for such work on ally... not having the bead will likely lead to pipe popping off
Well yes obviously having a lip on the end of the pipe is always essential (I though it goes without question)
I will be installing my front mount intercooler (Spiarco) in about two weeks with my SEM manifold
I will be fabricating the pipes using 6061 aluminum 2.5” hot side 3” cold side with a transition to 3.5” Hemi TB
Both ends will be connected to turbo housing and TB with V-bands I will post the Wright up as soon as I finish it
Setup is intended for 800hp
Rob do you mind me asking what angle of pipe you have coming off the charge pipe. Where the forge/ hose would usually be. Looking to make mine hard pipe all the way from charge pipe to inlet manifold with only connections being hose.
Thanks Mark
We are not all pro welders with access to mandrel benders, bead rollers, etc. so we just have to do the best we can.
I can take pics of the squashed alloy pipes that I had, I gave up on alloy pipes hence going for SS pipes, no problems at all now.
You have any links to your motor or others?actualy yes there are a few around
