Instrument Cluster Replacement
Nov 27, 2024
MK4 2021 FR 1.0T
Hi, first post I cant seem to see this has been queried before on other posts. Apologies if it has.
Is it possible to replace the instrument cluster myself? - basically the current digital dash display has a portion of dead pixels and it seems to be getting worse with time I've found replacements online but is it possible to do it myself as ive also seen on some forums that some vwag cars they need to be coded in or something possible to do with the key/immobilizer/mileage.
Any help on this greatly appreciated
leonlad
1,195
69
london
MK4 2021 FR 1.0T
you can buy new lcd screens if you are prepared to take it apart.
Reactions: ConZoz
cairus
1,240
447
which is not available as a spare part from Seat. You have to buy the LCD screen from the man in the East 😉 but be careful, I don't know it off the top of my head for MQB EVO, but removing and unplugging the speedometer can result in various basic settings being lost and having to be redone.
leonlad
1,195
69
london
i know but should be easy to find on ali. $100 :ROFLMAO:
i,m sure removing would be ok if ignition off ;)
might be that one
Nov 27, 2024
might be that one
Thanks for reply, i have no issue taking it apart ive replaced screens on many phones and ipads including digitisers and stuff. I saw a post where some guy removed his on mk4 for cleaning apparently and when he plugged it back in and turned ignition on it said instrument error but car worked fine, he said he left it over night and then it was okay ¯\_(ツ)_/¯
cairus
1,240
447
If something goes wrong, the vehicle is no longer roadworthy. A new one costs around 1000€
leonlad
1,195
69
london
unplug it and plug it back in to see what it does before trying to change anything
cairus
1,240
447
es ist wahrscheinlich das, aber ich muss es öffnen
This is normaly Golf 8 Touch Radio Display
I am not Sure ...😅
I think it's true, according to the 2021 price list as an example, the virtual cockpit has a size of 10.25".
Ich habe das hier gerade auf AliExpress gefunden:
€424.83 | LCD-Display für Volkswagen Golf 8 VIII Passat B8 Arteon Instrument 2021 2022 2023 Reparatur DK103IA-06A
