Initial Idle
Ricardo
Leon Cupra R 265 bhp
Oct 20, 2006
100
Milton Keynes
Guys, what effects idle? I always allow mine to warm up (LCR) when starting from cold. So does my friend from work with an LC. When we leave work he has buggered off and I am left waiting ages before the idle speed drops from 1500 rpm to 800. It takes 5-7 minutes which I am pretty sure is excessive. If any one has ideas for things I can check, clean, kick please let me know.
May sound odd that I dont just drive off with high idle but for some reason I get a lambda fault code if I dont wait for it to drop.
Ricardo
Oct 20, 2006
100
Milton Keynes
The worry I have is that it takes a long time to settle to normal revs, I will have a hunt and try to find out more on the thermostat, cheers.
Ricardo
Oct 20, 2006
100
Milton Keynes
Thanks mate thats what I was looking for. So mine does have some sort of problem. Now I just need to find out what controls the idle speed from start up and why it takes so long to drop.
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
my car only seems to idle for about a minute, i start the car, take it out the garage and then lock the garage and idle then goes off, pretty quick in mine.
Ricardo
Oct 20, 2006
100
Milton Keynes
Thanks for your help, its appreciated, I think I will flush the coolant and change the sensor again, looked in my bottle and its full of little black bits which isnt good so fingers crossed.
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
mate, try a throttle body reset... helps settle the idle quicker, or try cleaning it then resetting.
did mine and it helped, although mine never took 7 mins, bout 3 normally, a minute now.
