Indicator Stop working
golfather1
Hi Guys
I think my indicator relay is gone, I already check fuses & Stalk all fine.
Now I need your urgent help
Do we have a guide how to replace it or where I can find this relay in my car?
also if anyone can advise me where is the best place to buy this relay or its only a Dealer part?
Its 1.6 2000 model Leon
Thank you for your help in advance
Sal
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
The relay is built into the hazard warning switch.
You need to carefully remove the plastic surround, then you can prise out the switch.
You can buy a replacement from the dealer.
But - before you do - what happens when you press the hazard warning switch?
golfather1
Hi Mate
If I press hazard warning its working fine, it’s just when I use stalk to indicate
It works only for few seconds then stops.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Do all your bulbs acutally work as well?. Have you checked each one is flashing?.
Mike Green
Cupra crazy
May 4, 2007
431
Surrey
yeah - you may have a loose connection between the bulb and the connectors in the holder. I had this. If you think it is this all you need to do is bend in the metal prongs so the bulb has a better contact.
golfather1
I have checked everything
its a RELAY because when indicators stop working & I touch the relay they start working
for a bit then they go off again.
so now I have to go & get the relay
JOB DONE
cheekyman73
Hi
i have an indicator issue too... everything works fine when I indicate right but when i go left the indicates flash rapidly and the front one doesnt flash at all...
Please help on what to change...
wheres the best place to get a relay replacement from ?? they seem like gold dust...
cheekyman73
Have changed the bulb and still nothing.. also sprayed the electrical connections...
the light doesnt work with stalk or hazard switch....
all lights (apart from front left) flash normal on hazards but go wild with stalk..
