Idle problems 51 plate Leon
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Not hard if you're careful.
You should kill the fuel pressure (preferably remove fuel pump relay while engine is running) and disconnect the battery.
Undo the fuel rail mounting bolts and lift away. The injectors will come with it. The injectors have small metal clips holding them to the fuel rail. You need to make sure you don't lose O rings off the injectors.
Haynes Manual for Golf & Bora 2001 to 2003 always handy for more detail.
WarChild007
40
Reading
:thumbup:
WarChild007
40
Reading
Had a look at swapping the injectors around mate, but I think I need to take the upper part of the intake mani off (couldnt get all the bolts out and didnt want to snap the heads off) so left it. :(
