Reet then people, I hope someone can help a fellow SCN member out.
This is from 20vtwy's Ibiza Cupra - met up with her today as she can't get VAG-COM to work on her laptop.
She has had a ko3s turbo put on, decat, n75j & recirc valve - custom remapped. Rolling road showed 225BHP (approx)
Since the lack of power occured she has replaced MAF (genuine), Coilpacks (genuine) & BOSCH Spark Plugs, the coolant sensor has also been replaced.
No one has cleared any faults so this is what was logged when I first hooked up VAG-COM.
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
4 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13404
Shop #: WSC 11111
No fault code found.
Address 08 -------------------------------------------------------
Controller: 6K0 959 291
Component: AUTOCLIMA-220 X06.00
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6K0 920 901 D
Component: 6K-KOMBIINSTR. VDO V02
Coding: 00442
Shop #: WSC 00000
IMMO-IDENTNR: SEZ7Z0A1286933
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
01176 - Key
07-10 - Signal to Low - Intermittent
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 56 -------------------------------------------------------
Controller: 6K0 035 186 C
Component: Radio GRO 1V32
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
00853 - Loudspeaker(s): Rear
36-00 - Open Circuit
End -------------------------------------------------------
Coding: 10500
Shop #: WSC 00000
4 Faults Found:
Coding: 13404
Shop #: WSC 11111
Coding: 00442
Shop #: WSC 00000
2 Faults Found:
01176 - Key
No Faults Found
Coding: 00401
Shop #: WSC 06402
1 Fault Found:
