Ibiza FR 1.4 EcoTSI ordered
Tylerjet
135
Groningen, North Holland
FR2013 - are your rear windows darker than the fronts?
You can see there slightly darker
bcr5784
235
Thought I'd add my 2p here. The ride is much better in the new FR on 17's than it was in my old FR on 17's. But I've got no other car to compare it to!
I tested both a 1.2 on 16s and a 1.4 on 17s and the 17s were definitely harsher (and noisier) particularly in the back. \it is exactly what you would expect buth the trouble is if your dealer has set the pressures wrong it's easy to be mislead.
markm49uk
401
28
Hull,UK
I'm not bothered either way but her indoors might moan a bit - I prefer a firmer setup for handling purposes personally.
markm49uk
401
28
Hull,UK
Another question for you guys who have your Ibizas - how is the gear change - is it smooth and precise with a relatively quick action or is it a bit mushy and slow?
and yes I know you have the DSG FR2013 so I know your response ! :)
Fr2013
359
26
My previous FR was a lovely smooth gearbox, however this was the slightly older 5 speed box paired to the older 1.2 TSI.
Now I've forgotten what a clutch is, can someone explain? :D haha
bcr5784
235
I found the 1.2 Gearbox slicker (on both the Ibiza and Fabia) than the 1.4 too.
Fr2013
359
26
Stuck my number plate LED's in over the weekend. This morning on my (dark) drive to work, I noticed that I have a bulb warning 'check number plate bulb' on the dash!
These worked perfectly in my 2013 Ibiza FR so something has definitely changed with the CANBUS system. Anyone upgraded theirs to LED and have no errors? I'm now after some new bulbs as I still 100% want LED as it looks brill!
markm49uk
401
28
Hull,UK
It really does seem a bit of a nightmare area regardless of the make of car.
