The option I choose was the rear view camera, everything else was standard over here
FR2013 - are your rear windows darker than the fronts?
Thought I'd add my 2p here. The ride is much better in the new FR on 17's than it was in my old FR on 17's. But I've got no other car to compare it to!
You can see there slightly darker
I tested both a 1.2 on 16s and a 1.4 on 17s and the 17s were definitely harsher (and noisier) particularly in the back. \it is exactly what you would expect buth the trouble is if your dealer has set the pressures wrong it's easy to be mislead.
Looks nice parked on the drive way....
That is a large driveway!
My previous FR was a lovely smooth gearbox, however this was the slightly older 5 speed box paired to the older 1.2 TSI.
Now I've forgotten what a clutch is, can someone explain? haha
Stuck my number plate LED's in over the weekend. This morning on my (dark) drive to work, I noticed that I have a bulb warning 'check number plate bulb' on the dash!
These worked perfectly in my 2013 Ibiza FR so something has definitely changed with the CANBUS system. Anyone upgraded theirs to LED and have no errors? I'm now after some new bulbs as I still 100% want LED as it looks brill!
