Hybrid K04 Turbo Discussion
Mitchy
TTRS
Oct 12, 2004
2,310
Patched them all up (I think) and gauge is reading 1.45 - 1.5 bar @5000rpm :)
Yeah that sounds about right, i have 1.5bar upto about 5000rpm.
When you get laptop, you could also try adjusting wastegate actuator? keep an eye for boost creep, if you start to notice it, slacken wastegate flapper back off.
Made a difference for me but i guess i was off your mark in the 1st place:(
Mitchy
TTRS
Oct 12, 2004
2,310
I can connect it via my pc with long serial cable out of the window :lol: Can't do moving logging though!
What boost you getting @ 6500rpm now Mitchy in 4th gear? No nitrous
Around 2220-2250mbar mate.
The way i understand boost creep is....
Example....24psi/21psi/21psi/21psi/21psi/20psi/19psi/18psi/17psi/18psi/19psi/20psi
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
my boost creep is from undersized wastegate actuator..... so cant bleed out enough, as opposed leak by wastegate from insufficient spring rate which is indicative of a bigger compressor than turbine, hence high manifold pressures to push open the puk.
YerMother
comes and goes
Sep 22, 2004
1,461
East Midlands Drives: Scirocco GT
Finally took some logs last night after "borrowing" my house mates laptop!
Did a 4th gear run which is below.
8.01 3920 191.7 99 Part Throttle
13.54 6200 143.6 161 Part Throttle
The closest speed to 60 - 100 are above! 99kph (61.5mph) & 161kph (101mph)
So 13.54 - 8.01 = 5.53 secs! Was slightly downhill though but still quite impressed. Ambient temp was 13'C
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Part throttle too! Just think what it could have been if you'd had your foot down, Sie! :D
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
nice results Sie, similar to Mitch!
I really must do a time log from 60 - 100 to get a comparison of a max'd out LCR OEM Ko4 to your hybrids! :yes:
so just remind me someone please :redface:... how do i do it in vag com?! I have seen a link before but can remember where and don't have time at the mo to search! ;) :redface:
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
Good stuff, just wanted to make sure it was easy and didn't involved juggling a laptop, stopwatch and trying to drive!
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
:lol:
I set the log off before I pull away. I leave the mouse hovering over the 'Marker' button and click just before each power run. The markers make each run very easy to find amongst all the other superfluous figures.
RobM
Sep 27, 2006
4,982
Southampton
That's what I did when logging the MAF, just wasn't sure if the markers would be there for all loggings. Cheers for clearing that up :)
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Yep, 4th. Start logging at 40-50mph and hoof it all the way. Pick up the speeds and times from the logs later.
