Does there seem to be abit of a boost leak to you? Reason i ask is that she used to spike at approx 26psi but now just touching 25psi on gear changes.
The logs on the right hand side are from about a week ago when the gauge was spiking 26psi and the ones on the left from Sunday evening, now to my knowledge it looks like the most recent set of logs looks to be boosting better that the previous lot but the gauge says different, dodgey gauge?
Also it seems to be boosting 1.4bar at the redline, yet the gauge says 18/19psi. also it seems to drop mid range and then pick right up again near the redline?
Also it seems that the WG duty has gone up by 3%.
Code:
Sunday 26 July 2009 19:55:23 Tuesday 18 August 2009 20:01:00
6K0 906 032 AA 1.8L 20VT EU3 01 0002 6K0 906 032 AA 1.8L 20VT EU3 01 0002
Group A: '115 Group B: Group A: '115
RPM Load Absolute Pres. Absolute Pres. RPM Load Absolute Pres. Absolute Pres.
TIME TIME TIME
MARKER STAMP /min % mbar mbar STAMP MARKER STAMP /min % mbar mbar
0.01 1400 75.9 1690 1110 0.34 2280 119.5 1880 1540
0.36 1440 78.2 1720 1130 0.74 2360 133.8 1910 1640
0.76 1480 79.7 1740 1150 1.14 2400 146.6 1940 1750
1.16 1520 83.5 1750 1170 1.54 2480 157.1 1980 1880
1.56 1600 85 1750 1190 2.05 2600 169.2 2030 2050
1.96 1640 85 1750 1210 2.55 2760 175.9 2080 2220
2.36 1680 85.7 1750 1230 2.95 2880 188 2120 2340
2.76 1720 88 1750 1250 3.35 2960 191.7 2150 2410
3.16 1800 91 1750 1270 3.75 3080 191.7 2170 2440
3.56 1840 94 1760 1290 4.15 3200 191.7 2190 2400
3.96 1880 94.7 1780 1310 4.55 3280 191.7 2210 2370
4.36 1920 99.2 1790 1340 4.95 3400 188 2230 2340
4.76 2000 103.8 1800 1370 5.35 3520 183.5 2250 2310
5.16 2040 107.5 1830 1400 5.75 3600 181.2 2280 2290
5.56 2120 109.8 1840 1440 6.15 3720 181.2 2300 2280
5.96 2200 115 1850 1490 6.55 3800 183.5 2280 2300
6.45 2280 122.6 1880 1560 6.95 3920 182.7 2290 2270
6.85 2360 135.3 1910 1640 7.35 4000 181.2 2290 2270
7.25 2400 144.4 1940 1730 7.75 4120 178.9 2290 2280
7.75 2520 156.4 1990 1880 8.15 4200 180.5 2280 2300
8.15 2600 163.9 2020 1990 8.55 4320 182.7 2280 2300
8.66 2720 170.7 2080 2140 8.95 4400 185.7 2280 2290
9.06 2800 178.2 2110 2240 9.35 4520 188.7 2280 2310
9.46 2960 186.5 2140 2350 9.86 4600 191 2270 2310
9.86 3040 191.7 2140 2430 10.34 4760 190.2 2270 2290
10.26 3160 191.7 2170 2480 10.76 4840 191.7 2240 2290
10.66 3280 191.7 2180 2450 11.16 4920 191.7 2240 2280
11.06 3360 191.7 2200 2380 11.56 5000 191.7 2240 2250
11.44 3480 187.2 2230 2340 11.96 5080 191.7 2260 2260
11.84 3600 181.2 2250 2310 12.36 5160 191.7 2270 2260
12.24 3680 180.5 2270 2300 12.76 5240 191.7 2280 2260
12.66 3800 182 2280 2280 13.16 5320 191.7 2290 2270
13.06 3880 178.9 2280 2270 13.56 5360 191.7 2310 2280
13.44 3960 182.7 2290 2250 13.96 5400 190.2 2300 2270
13.86 4120 181.2 2280 2290 14.36 5520 189.5 2310 2260
14.24 4200 182.7 2280 2300 14.76 5560 187.2 2330 2270
14.66 4280 179.7 2280 2300 15.16 5600 188 2340 2280
15.15 4400 180.5 2270 2290 15.56 5680 186.5 2350 2290
15.55 4520 183.5 2270 2300 15.96 5720 186.5 2360 2290
15.95 4600 187.2 2250 2310 16.45 5760 188.7 2380 2380
16.35 4680 188.7 2250 2280 16.85 5840 191.7 2390 2440
16.87 4800 191.7 2240 2280 17.25 5880 191.7 2360 2460
17.27 4880 191.7 2240 2270 17.65 5920 191.7 2360 2490
17.67 4960 191.7 2230 2250 18.15 5960 190.2 2350 2500
18.07 5040 190.2 2240 2260 18.66 5960 191.7 2350 2470
18.47 5120 191.7 2260 2260 19.06 6040 188 2350 2470
18.85 5240 190.2 2270 2270 19.46 6040 188 2350 2440
19.25 5280 190.2 2260 2260 19.86 6640 87.2 990 2530
19.65 5320 188 2270 2250
20.05 5400 186.5 2280 2270
20.45 5440 186.5 2290 2250
20.85 5520 184.2 2310 2270
21.25 5560 185 2320 2260
21.65 5640 185.7 2330 2280
22.05 5680 185 2350 2290
22.45 5720 186.5 2340 2290
22.85 5720 186.5 2350 2300
23.25 5800 185.7 2360 2310
23.65 5840 185.7 2360 2320
24.05 5880 185 2350 2330
24.45 5920 185.7 2350 2320
24.85 5960 184.2 2350 2320
25.25 5960 184.2 2340 2330
25.65 6000 184.2 2330 2310
26.16 6040 182 2320 2330
26.56 6040 183.5 2330 2320
27.06 6040 181.2 2320 2320
27.46 6120 182.7 2330 2340
27.86 6120 179.7 2330 2340
28.26 6800 28.6 990 2220
28.66 5120 121.8 2260 1320
