Hi,
sorry for the amature question but my Leon 1.8 has been a bit iffy starting for a few months now. Problem seemed to start off a while back with a bit of a spluttery/sluggish start every now and again but one day I got in and it turned over and wouldn't fire up at all. I moved it on the starter, rocked it a bit, tried all the doors, tried patiently doing everything slowly with the key/ignition/door locks incase it was immobiliser related, but it wouldn't start. When the AA man turned up, it started first time of course. He couldn't diagnose a fualt that wasn't there but suspected crankshaft sensor.
A couple of times within the last few months it's failed to start but each time it's recovered after my usual war dance until today when my wife got stuck in camberley.Tried everything to no avail and the AA man this time diagnosed no signal from CPS Sensor apparently using his computer.
So....I'd like to replace this myself and by all accounts it involves dismantling loads of the engine bay (according to AA).
I'm not sure it can be that difficult...so thought I'd ask you guys ! (I'm no mechanic but I did drop the engine out of a Skoda with my wife once, to replace a spigot bearing...so I guess I fall into the practical, but no experience or knowledge category ;-) - we were successful with the spigot replacement btw ;-) )
From reading other posts, seems some confusion over which is the camshaft and which is the crankshaft, so thought I'd post my pics of where I rekon it is...that is...bolted into the front of the engine, in the void between the oil filter and the engine...I took on pic from above, and a close up from underneath with my phone close to the oil filter)
Not sure if this forum is allowing me to post images but the links are below this line...
https://picasaweb.google.com/lh/photo/hh6Cc3mI7LNDcQWj0gmPVU-V7q28XGSt5kT3KHnXlkU?feat=directlink
https://picasaweb.google.com/lh/photo/ezaR1e_-T8sUvKdsGZ4DpU-V7q28XGSt5kT3KHnXlkU?feat=directlink
AA man made it sound like it would be a pain to get to but I rekon I could get a socket to that without much trouble (anyone able to tell me what mm size it is to save me rounding it battling with the rust would be helpful !).
If that is the one I need to remove...I suspect it's the routing of the cable that becomes the bigger issue for me ? Seems it meanders between some pipes at the front of the engine before dissappearing under the exhaust manifold (I haven't taken the engine cover off yet so maybe it looks more tricky than it is...).
So...any idiot guide would be very helpful...it's not so much the not knowing how to do it...it's more the pain I'll feel if I start a job and find I have to give up ! so if I have to dismantle engine brackets, drop gearboxes out and generally have my engine supported on various bits of masonry..I'll have to resign myself to failure ;-)
cheers,
Ant.
cheers,
Ant.
