How do you get the radio out of the mk5 ??
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
If you plan to run ipod you'll need both aux and usb, unless you can rig a splitter up or something.
andy15star
825
Durham
unless you wire up the OE aux plug to the dension aux plug. think thats the way i'd go?
Ah, good thinking batman !. But will the OE aux plug terminate into a 3.5mm jackplug to fit into the Dension 300 Aux in ?? (if ya kinda know what i mean !)
Regards,
Andy
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
Im currently running my ipod through the aux lead, tbh the lack of functionality is getting me down so the sooner I get a system in there the better.
andy15star
825
Durham
URGENT HELP !!!!
I disconnected the OE unit to see what the connections were like, i put it back in with a view to ordering the Dension 300 and it's is now asking me for a code !!!!! - where do i find the code to get the radio working again ???
Seat tech line are now closed !
I cannot find it in the radio handbook either, just 3 sticker barcodes
HELP !
Andy
andy15star
825
Durham
PANIC OVER ! :)
For some reason, if you leave the unit a few minutes it comes back on. Wonder why it asks for the code when you re-connect it back up, then automatically puts the cos back in for you (or bypasses it) 2 mins later ! - oh well it's back in and working now.
Regards,
Andy
andy15star
825
Durham
A couple of further problems/questions in the photo below (excuse the quality of pics from my phone !)
The guy at Autosounds is going to have to ring Dension as he's not sure if its compatible with the Blaupunkt OEM radio which is in the car (ps i didnt realise it was made by Blaupunkt till i took it out of the facia !)
Excuse the larger size pic, i'm not sure how to make it smaller for this forum :(
Regards,
Andy
Regards,
Andy
At the bottom of that picture there is a hinge pull it up and it should pop out:funk:
andy15star
825
Durham
Hi, yeah i've had the whole cluster out, what i meant was that the black smaller block (with the wires running into it) cannot be prized out, it seems to be welded to the larger block housing ???
Regards,
Andy
andy15star
825
Durham
if you look at the bottom of the quad lock there will be a tab to push/pull to release the lock it will then hinge up and away from the bottom of the stereo unit.
Hi there, i think we're talking about different things here. I mean the little small black plug (about 1cm by 2.5cm) is attached (stuck) to the main larger block (the block which is about 4cm by 4cm). There is no tab or lever on the smaller plug to pull it out. The only way is to tug on the wires, but i can see that there is no gap there like the other plugs, it seems welded !
Andy
andy15star
825
Durham
Its called quad lock, there's no need to get that out of the big block.
So does the whole of the larger block need to stay out when the Dension 300 is plugged in. Not sure how it works to be honest.
Does the Dension 300 plug into the back of the radio, then the original looms (with connectors on) plug into the Dension 300 ?
Regards,
Andy
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
The connector is the same as anything fitted to any current VAG vehicle. The quadlock is pretty much a universal fit these days, the power, earth and s contact feeds are all in the centre bit which cant be removed but the pins can be with the correct tool.
Lets have a look at the plug on the end of the Denison please. Also you stereo will come back on when ypu turn the ignition on. If you dont have the code (which they dont all come with them) the dealer has to plug it in and get it online from SEAT.
