Hissing noise from brake pedal?
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Dan, as you engine will be out it "should" be a piece of piss, the only issue i would say you might have is getting the clutch pedal of the push rod going into the servo as you can see there is a ball joint on the rod, a small plastic clip goes onto this, i had to destroy the one on mine and order a new one from Dave, its only pence so worth having even if you do manage to get yours of in one piece, which i doubt as its a pig, other than that as i say it will be easy with the engine gone.
SWANSWAY CUPRA Dealership
