High idle leon 2.0 tdi
Leo5559
14
Hello guys
Sometimes the car runs on 1000 idle rpm instead of 850.
https://drive.google.com/file/d/1rogy_Ls-2QWg2ok4r16CwZns-_WIGAfx/view?usp=drivesdk
As you can see from the video the car is on working temperature.
So this is not happening all the times, since last 10 months its happened 4-5 times.
And after I restart the engine the car is idling normal...
Is this any problem or???
Maybe is the fuel quality problem or someting related to the fuel because I ve been investigating when this is happening and I concluded that when the fuel tank goes around 2 dots or range below 120 kms this is happening.
Maybe is coincidence but who knows.
What do you think?
Copra68
549
306
Don't turn it off whilst it's doing a regen or it will never complete and the dpf will become clogged/full. Rev it gently for a few minutes when your parked, touch the accelerator pedal and if the revs drop to normal then turn the car off.
Reactions: Leo5559
stu_m
630
52
Hull
www.themotorbikeforum.co.uk
The light will only come on if the regen fails to complete about 3-4 times in a row!
There really is no need to do as you are suggesting when its doing a regen! the regen will restart again when you next go for a drive and it starts to reach temperature
There is a lot of miss information out there regarding DPF regens and there is really no need to do anything different except if you know you haven't completed a regen about 3 times in a row then maybe take it for a little drive to allow it to complete ther is no need to drive in high gears or drive it like you stole it either like a lot of other people recommend
In 4 years of owning my tdi I have had the light on once and ironically I posted on here the day before saying I had never seen it on! but I had done lots of stop starts with journeys of a mile or less in a week period and each time it was trying to do a regen! I just took it for a drive up the road for about 6 miles and all was done
Reactions: Copra68
