HID projection issues
GTV
Veggie powered TDi's
Feb 16, 2008
479
Cambridgeshire
here you go
beezertart
**MAYHEM**
Sep 11, 2007
1,260
beyond the sun
ah at least i know what i'm looking for now!! cheers gtv,think will be a wheel off job though as with the angel eyes being a single unit,it's painful to get to that area,bumper off and all that :(.getting dark now so tester time coming up
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
She had projection issues cos someone fitted H7 bulbs in an H1 one light. Fitted H1 for her this evening and it's 100% better however i'm still not happy with how they fit, looks like the bulb might even be a short H4 on those light units.
Didn't realise until today how flakey the electrics on the Mk2 are .... with the HID lights on, the car didn't even have enough juice to crank the engine. Can you not fit bigger batterys to these - does that cure the issue?
beezertart
**MAYHEM**
Sep 11, 2007
1,260
beyond the sun
PAH,H1,H7'S.same difference ;) seriously though, even though i shoved h7's in they were a whole world better than the h1's that came out so seems those bulbs were naffed. strangely enough,after the incident of the car not firing,she's had no further issues and low n behold the clocks aren't going mental either:D finally!! however i definitely need to get them sorted properly....cheers Pat for the help!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
that's the resistor ye
did i read that right ? you managed to get H7 bulbs into a H1 Headlight ?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
safely report no issues at present on install - with resistor unplugged i must add
i have 12w halogen sidelights with 55w hid (6000k) mains and 130w high beam
been fitting testing and glowing em up all night and not even a flicker so far
high beams looks dull now though :p lol
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
I know what you mean about the high beam, Ive got a h4 hid kit and the low/dipped beam is brighter than the high, been flashed at loads.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
all finished and setup up and looks like you i cursed myself :)
noticed clock was at 12:00 - Doh!!!
works fine when on for a while and all warmed up but on initial turn on displays disappear for a second and needles in the speedo reset
will add relays to em later but minor hassle right now to be honest
UncleFester
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
Too much like hard work for a saturday although there's a lot more room in the Mk2 Ibiza ..... if you take out the battery and airbox. I don't think anyone with big hands could do it thats for sure./
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ye i guess i am used to it - never bothered me but long handled angle nose pliers help :p
Ibiza 2 bulbs - easy
Ibiza 3 bulbs - tight but doable at a squeeze
Leon is tight but easier than a mk3
as for a ford Ka well - lose ya knuckles
and a Renault Modus - take bumper and grille and lamps out first (not kidding)
