So was the electrical connector on the right side, and the longest stud went to the actuator instead on the TIP? Just curious...lol
No mate the longest stud was in the TIP (as it should be) but the other two studs had the wrong pipes connected.
Correct piping - Pipe from charge pipe should connect to bottom stud (vertical)
Acutator pipe connects to the rear stud (horizontal)
mine were the other way around since buying the car causing lambda faults and low boost (7psi max).
