Help with fault codes
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Right, got a problem with the Mrs' GT Sport 1.4TSI..
Scan results as follows....
3 Faults Found:
012296 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 0
Fault Frequency: 4
Mileage: 93857 km
Time Indication: 0
Date: 2000.00.00
Time: 17:52:53
Freeze Frame:
RPM: 697 /min
Load: 11.8 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.716 V
008851 - Fuel Pressure Regulator Valve (N276)
P2293 - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 3
Mileage: 93863 km
Time Indication: 0
Date: 2000.00.00
Time: 13:36:26
Freeze Frame:
RPM: 1218 /min
Load: 16.5 %
Speed: 14.0 km/h
Temperature: 22.0°C
Temperature: 12.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Mileage: 93863 km
Time Indication: 0
Date: 2000.00.00
Time: 13:36:45
Freeze Frame:
RPM: 3017 /min
Load: 68.6 %
Speed: 43.0 km/h
Temperature: 24.0°C
Temperature: 11.0°C
Voltage: 14.351 V
Any thoughts?
towcester vag
1,775
duston northants
fuel pressure regulator playing up
there is a write up on here or vwaudiforum about repairs to these
the camshaft posistion sensor probably came on due to excessive cranking of the car to get started
Damoegan
Oct 15, 2007
8,993
Newcastle
The car has never failed to start so we can count out the excessive cranking.
Any link to the thread on the repair
Damoegan
Oct 15, 2007
8,993
Newcastle
Camshaft Position Sensor all sorted BUT....
Fuel Pressure Regulator Valve (N276) P2293 - 000 - Mechanical Malfunction..
New fuel filter fitted and new HPFP fitted but the car wonte start :(
Deleted member 74601
Sorry I can't help you, but just wanted to know how you fixed the Camshaft sensor?
meth
@Damoegan
Hello
I have the same problem
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 75659 km
Time Indication: 0
Date: 2000.00.00
Time: 21:16:56
Freeze Frame:
RPM: 4411 /min
Load: 94.8 %
Speed: 171.0 km/h
Temperature: 87.0°C
Temperature: 27.0°C
Voltage: 13.843 V
My car is from group VAG
Golf GT Sport TSi 140 model 2008
I change HPFP but the problem still remain, dear friend Damoegan do you found any solution?
I can't found any solution from group VAG official service-dealers
Thanks in Advance
Damoegan
Oct 15, 2007
8,993
Newcastle
You wont like my reply my friend...
It turned out to be a screw had dropped into the timing chanin causing the timing to chump, resulting in 5 snapped valves :(
VOLKSMASTER
we have the same car in our garage today with exact same faults and cylinder 2 valve has clipped (not good )
