Right, got a problem with the Mrs' GT Sport 1.4TSI..
Scan results as follows....
3 Faults Found:
012296 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 0
Fault Frequency: 4
Mileage: 93857 km
Time Indication: 0
Date: 2000.00.00
Time: 17:52:53
Freeze Frame:
RPM: 697 /min
Load: 11.8 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.716 V
008851 - Fuel Pressure Regulator Valve (N276)
P2293 - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 3
Mileage: 93863 km
Time Indication: 0
Date: 2000.00.00
Time: 13:36:26
Freeze Frame:
RPM: 1218 /min
Load: 16.5 %
Speed: 14.0 km/h
Temperature: 22.0°C
Temperature: 12.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Mileage: 93863 km
Time Indication: 0
Date: 2000.00.00
Time: 13:36:45
Freeze Frame:
RPM: 3017 /min
Load: 68.6 %
Speed: 43.0 km/h
Temperature: 24.0°C
Temperature: 11.0°C
Voltage: 14.351 V
Any thoughts?
3 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 93857 km
Time Indication: 0
Date: 2000.00.00
Time: 17:52:53
Freeze Frame:
RPM: 697 /min
Load: 11.8 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 33.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 93863 km
Time Indication: 0
Date: 2000.00.00
Time: 13:36:26
Freeze Frame:
RPM: 1218 /min
Load: 16.5 %
Speed: 14.0 km/h
Temperature: 22.0°C
Temperature: 12.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 28
Mileage: 93863 km
Time Indication: 0
Date: 2000.00.00
Time: 13:36:45
Freeze Frame:
RPM: 3017 /min
Load: 68.6 %
Speed: 43.0 km/h
Temperature: 24.0°C
Temperature: 11.0°C
Voltage: 14.351 V
Any thoughts?
