Hi mate just found this in one of the threads by cjhawker,this could
help
COMMON ISSUES
Make sure the ignition is on. Don’t have to start the engine for 90% of things
If getting comm. Errors lower the Baud Rate in the Comm port setting in windows
device manager.
If having trouble or cant connect to Address 46: Central Conv
Try removing then reinserting these fuses to restart the module (easier than
disconnecting the battery):
Number 14 - (10A) is in the manual as interior lighting, central locking/electric
windows. It also has underneath a 5A marked down for Interior light but still under
14.
Number 38 - (10A) is boot light and also central locking/electric windows.
hope it helps,i had this at the weekend,wouldn't connect,then an hr later it would
i blame the e-bay cable tho,gonna invest in the proper one from ross-tech
