Help sunroof rattles
coolantrs
17
Hi all,
i have seat leon Cupra 2019
in the past few month i have a lot of sunroof rattles when he in close position, when i lift him up 95% of the noises despaired
some one can please help me i don't know what to do
thanks
rafletcher
531
214
If it’s a 2019 car, is it still under warranty in your country? In the UK its 3 years. It does, unfortunately, seem to be a common problem with the pan roof.
Cuprabenwytm
323
110
Is a seat if you cure one rattle another will appear, or thats what i have found with mine lol
Sent from my MRD-LX1 using Tapatalk
Reactions: Slickric21
Slickric21
561
254
Norfolk
Sadly this is true.
However sunroof rattled can usually be solved easily (providing nothing has come loose) with either Silicone spray or Gummifledge lubricant around the rubber seal, both inner and outer and the back seal where it sits when closed.
Sadly once you start this it’s a constant battle to maintain and will need re doing every few weeks.
There is a special lubricant called Krytox that is designed specially for this job, it’s expensive but lasts much much longer
seatgraham
499
58
Hi all,
thanks
There is a post on this forum with the official workshop maintenance. You could look at that.
seatgraham
499
58
can you please share link with the official workshop maintenance.
Have a look at this post. The information is for panoramic sunroof however should be similar advice regardless of model/sunroof size:
