GT_power
Hello, friends!
Please, could you help me to resolve a problem with my Ibiza`s engine:
The car is made 1997 with engine 1.6i 101hp (engine code AFT).
The problem is that the engine has a big vibrations when a start it:cry:
That is only when the engine works in 0 gear - I mean when the car not moving. When I am driving it there is no such problem - the car works perfect.
I made it a ECU diagnostic, but the diagnostic doesn`t show any problems :confused: I checked the fuel pump, lambda sensor, air flow meter and everything which can be checkеd whith this diagnostic but nothing:confused: THe diagnostic shows the everithing is OK - all parts are in good condition but the engine vibrating.
I do not know what to do, what else to check?!:cry:
Please, help me with advice:(
ps: I hope that you understanding my post?! My English is not very good and I apologize for that:redface:
Best Regards!
diagnostic on that model isnt exactly full of all the options
whats the cap and rotor arm like ?
and ignition in general
have you checked for air leaks ?
That is the engine:
Yes, I checked for air leak - all air pipes, connections and parts to air flow way - from air filter box to intake colectors. The ignition system is checked too: Ignition coil, spark plugs and cables, distributor.
Everything is OK, but the vibration problem exist:cartman:
did you checked the ideal ....i'm sure thats the proplem from it
