HELP - Need new Manifold ASAP
Robbie Romero
215
Hi,
I need a new manifold ASAP as mine is cracked, it is not just blowing from a gasket.
I've had problems with air leaks, this is the last item that I need to replace.
I have no idea what part to buy or where to buy it from.
PLEASE can anyone help me find the lowest price manifold for my car:-
2002 Seat Leon 1.8 20v Turbo (engine AUQ)
My boost was all over the place - all or nothing, fixed 1 air leak, replaced N75, replaced MAF.
Runs smoother but STILL not much boost, the turbo does kick-in but it doesn't seem to accelerate much different than a NON turbo car!
I get the odd code from time to time:
17704 - coolant sensor / thermostat (replaced both & temp works fine)
16847 - MAF signal too high (too much air so car uses more fuel)
17535 - long term fuel too rich
Aswell as the fact my car doesn't boost correctly I'm spending a fortune on fuel, in fact, since the new N75 & MAF were fitted I can visibly see the fuel gauge going down even afer 6 mile journeys! It is just about getting 200 miles to a tank, where as I used to get 350 easy!
Also concerned about my MOT, as surely the emissions will be VERY high & thus FAIL the MOT.
ANY help or words of wisdom MUCH appreciated.
I honestly need someone to all-but-buy the new manifold for me as I've got no idea of part number, where to purchase, best prices etc etc.
Robbie Romero
215
Bit more info...
My temp gauge was not holding a 90 temp, so I changed the Temp sender (green top).
Car seems fine, but takes at least 10-15 mins to reach 90 and only stays at 90 if stationary. When driving it falls back to 60.
Is this simply the cold weather or is my Thermostat gone? I already have a replacement Thermostat, but the garage will charge quite a bit in labour as I gather its not a quick job...
Robbie Romero
215
Any ideas roughly how long it will take to change the manifold, much invloved?
Guessing there is some welding to be done?
twenny
engine geek !!!
Oct 9, 2008
86
East Yorkshire
Er sorry to sound daft , but are we talking , Inlet mani or Exhaust ? you dont specify, id assume Exhaust
however If its the inlet mani ill have one soon just got to finish gasket matching and porting my replacement so i can swap them over ,
twenny
