As we know the heated mirrors are activated when the rear demister switch is pressed, however if I remember correctly the heated mirrors only come on at a certain temperature?
I was in work for 7am for the last 2 weeks and temp wise at that time of the morning it has not been below 12 - 15 degrees, so maybee it is just not cold enough yet?
Saying that Snoopcousins have worked allready?
Snoopcousins not being funny but your mirrors may have cleared on their own due to wind flow, were they warm to the touch?
If so then we can put this idea to bed..... :whistle:
i set off to work a 6.20am every morning and the temp at this time has been in between 7c and 12c, i would have thought they should have worked at this temp if this was the case?:confused:
my heated mirrors work at any time.... so below 12/15 degrees is not right.....
i can feel the heat off them now and the temp is like 18 degrees + .....
i bit off topic but do all of you have the mirrors that tilt when you engage reverse as mine does not and im told it should,
Oh yeah and only 1 of my heated mirrors works but it the drivers so thats a bonus
