heat soak or not???
Dec 3, 2007
2,475
cardiff
taffy taffy taffy. Tut tut tut . The reason you were getting a leak is because your dv was set open too much. And needed to be done up tighter. i told you this before! and this is also the reason for the extra mpg. And before you go stage 2 you need a new tip, Fpr, intercooler, exhaust, and i would seriously think about changing your filter . And as for the n75j these can cause some cars to go into limp mode but not all. As for the bypass you just need to order some resistors and then i will sort it out for you. I used my last resistor the other day for my evap system
TAFFY aka beast
loving a turbo car at 19
Oct 3, 2008
51
cardiff
nice one rhino.... ill have a look for sum over crimbo.... were u been all week????? thought u was coming out..... need to use the laptop sum time when your free
