Thanks so much I can finally get this done now =D
Sent from my SM-G955F using Tapatalk
the 351-357 zip file is password lock could i have the password to it please.
did you manage to find out which is the best recommended software to use to burn this, am not sure if using verbatim cd-r discs is the issue or not but once I burn it the file is on the disc but it just is not loading up when I put it into the unit.I can see which software was recommended later today.![]()
thanks il give it a goI used cdrwin 5.05!
It should work. You must burn the discs at the lowest speed possible.
I've tried it and alcohol 120 still having no luck. I've loaded it on to powriso which is saying that the image files are non bootable ?. Not sure if I am missing something here. Burned through 10 CDs already lolI used cdrwin 5.05!
Could you type in english please otherwise we will not know how to help you or understand what the question isHola.
¿Podrían publicar los enlaces nuevamente?
Muchas gracias
