GUIDE: The Mk2 Leon VAG-COM Guide
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
With the leaving home lights, when you unlock the car, the lights stay on for the set time (this can be changed).
Is this happening?
(PS: Not possible on all cars)
manuelerosso
thank yu for the link dan....do you have any solution less expensive???
i heard some notices....in my concessionary they tell me thet function are not available on my leon 1p of the yer 2005....(december 2005...) is true?
anyone has test it on that car???
thank you
keep an eye there...
are this cables right?(look the third.)
http://cgi.ebay.es/cable-Vag-com-70...ryZ16618QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.it/Btand-New-VAG-CA...hash=item350090982398&_trksid=p3286.m63.l1177
http://cgi.ebay.fr/USB-peut-OBDII-V...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
alx_chung
Dark Lord of the Torque
Sep 11, 2006
1,537
In front of a PC....
Is this happening?
Nope its not. When I unlock the car the lights do not come on. Guess I have one but not the other.
Alex
BlackMagicLeon
78
Hampshire
Have you tried it in the dark? I have half an idea that they are linked to a light sensor..
Having said that we turned both options (leaving and coming home) on on mine and it doesn't seem to do anything either..
alx_chung
Sep 11, 2006
1,537
I don't have a light sensor on the car so that could be the problem but like I said the coming home lights work ok. Oh well like Dan said it could be trial and error to get things working.
Alex
NickP
895
Colchester, Essex
Leaving Home Lights
This feature turns on your lights when you unlock the car (if your headlight switch is on). I believe this option is standard if you have the auto lights option. This also adds an option in the MFD lights menu for how long it will stay on.
Module 09 - Cent. Elects.
Coding
Byte 0
Bit 5 - Assistance Driving Light_Leaving Home active
Beep when locking/unlocking car (My favourite feature)
This adds a beep when locking the car, and two beeps when unlocknig the car.
Below; horn refers to the beep, and blink refers to the indicators blinking
Module 46 - Central Conv.
Coding
Byte 6
bit 0 unlocking confirmation (blink) via door locks
bit 1 - unlocking confirmation (horn) via door locks - (makes 2 beeps)
bit 2 - unlocking confirmation (blink)via remote control
bit 3- unlocking confirmation (horn) via remote control - (makes two beeps)
Byte 7
bit 0 locking confirmation (blink) via door locks
bit 1 - locking confirmation (horn) via door locks - (makes 1 beep)
bit 2 - locking confirmation (blink)via remote control
bit 3- locking confirmation (horn) via remote control - (makes 1 beep)
Dan - I was hooked up to Vag Com at the weekend, on Module 46 it was claiming Byte 6 & 7 didn't exist and the same problems when trying to turn the Leaving Home feature on - any ideas?
Nick
craigG
I have a 56 plate 2.0l tdi 140, I also have a vas5052 and have been through the whole process of re-coding the convenience and central electrics and it still just states remote total closure/mirror folding not possible for 2006 cars,also I can't find the setting for the beeping on locking and unlocking(maybe linked) Can anybody out there shed any light or is it an ecu upgrade needed?
DanGB
Feb 12, 2006
3,772
London
Im not too sure as I dont have a clue about the VAS system.
Unsuprisigly, the total closre with the mirrors wont work if its an 06 model car.
I cant see why the setting for the beeping isnt there really though.
Which trim level of car do you have? sport or stylance?
It wont be an ECU upgrade,a s the ECU doesnt control any of these functions. Its the individual control modules; ie convenience module, and central electrics module.
DanGB
Feb 12, 2006
3,772
London
Nick
Hi Nick, could you do me a screen shot of the page where its supposed to be, as can you do me and autoscan of all the modules please?
NickP
895
Colchester, Essex
I don't have a screen shot Dan, as it was someone elses Laptop, but Ken has emailed me the logs:
Saturday,13,September,2008,19:13:17
VAG-COM Version: Release 512.4-UD
Chassis Type: 1P - Seat Leon
Scan: 01 02 03 08 09 0F 15 16 17 18 19 25 36 37 3D 42 44 46 47 52
55 56 57 62 69 72 76 77 7D
VIN Number: *****************01
Address 01: Engine
Part No: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 0431
Coding: 0050072
Shop #: WSC 04941
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Part No: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Coding: 0006786
Shop #: WSC 04941
Address 08: Auto HVAC
Part No: 1P0 907 044 B
Component: ClimatronicPQ35 011 0602
Address 09: Cent. Elect.
Part No: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Coding: 81880F2F00041000431D00000000000000007F075C400000000000000000
Shop #: WSC 18434
Part No: 1P0 955 119 B
Component: Wischer 160807 022 0601
Coding: 00056208
Shop #: WSC 18434
1 Fault Found:
01334 - Door Control Module; Rear Right (J398)
004 - No Signal/Communication - Intermittent
Skipping Address 15-Airbags
Address 16: Steering wheel
Part No: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
Shop #: WSC 04941
Part No: XXX XXX XXX XX
Component: E0221 005 0060
Address 17: Instruments
Part No: 1P0 920 941 A
Component: KOMBIINSTRUMENT VO3 0724
Coding: 0002401
Shop #: WSC 01701
Address 19: CAN Gateway
Part No: 1K0 907 530 L
Component: J533__Gateway H15 0180
Coding: E9807F064004023203
Shop #: WSC 01701
3 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
01300 - Control Module for Navigation with CD-Rom (J401)
Address 25: Immobilizer
Component: IMMO VO3 0724
Address 37: Navigation
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver
Part No: 1T0 959 701 G
Component: J386 TUER-SG FT 1130
Coding: 0000688
Shop #: WSC 04941
Address 44: Steering Assist
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.142 H08 1901
Address 46: Central Conv.
Part No: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Coding: 998000005283CC7F0006850560085F86107C00
Shop #: WSC 04941
Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 04941
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
Address 52: Door Elect, Pass.
Part No: 1T0 959 702 G
Component: J387 TUER-SG BT 1130
Coding: 0000688
Shop #: WSC 04941
Address 56: Radio
No Faults Found
Address 62: Door,Rear Left
Part No: 1K0 959 703 N
Component: J388 TUER-SG HL 1108
Coding: 0000144
Shop #: WSC 04941
Address 72: Door, Rear Right
Part No: 1K0 959 704 N
Component: J389 TUER-SG HR 1108
Coding: 0000144
Shop #: WSC 04941
Address 77: Telephone
Part No: 5P0 862 335 B
Component: FSE_2P5x H23 0110
Coding: 0000555
Shop #: WSC 04941
End --------------------------------------------------------------------------------------------------
craigG
Its a stylance sport with winter pack. And why unsuprisinglly not there the total closure works on the key? In reading the thread dan gb says he has ao 06 with windows that close via remote, I would have thought only a firmware issue? the beep is also a convenience fuction
DanGB
Feb 12, 2006
3,772
London
So its a stylance with sports pack? I thought they only came in on the MY07, as a 'sport' was basically a stylance with a sport pack, which the sport was dropped on 07 MY when the FR came out.
Do you have a date of manufacture?
On 06 model year cars, total closure only works with the windows and not the mirrors.
craigG
thats it stylance with sports and winter pack, first reg sept 06
Correct no byte sectin for mirror folding and I cant activate remote conveience functions but cant understand logic why? dealer also stated its not possible hence my confusion when aparently it HAS been done!
