Here's what I did ... the ATP inlet kit is a bit of a nightmare, the cast oval pipe under the shifter cables etc., I did try and fit it, I got it all in but a metal water pipe is right in the way and it was jammed against the left shifter cable, which meant I couldn't get the car into gear, so out it all came again!
Star had already fitted a steel plate with 4 holes in it, which moved the shifter cables 2-3 inches away from the turbo entry - I refitted that and found that an ATP 2.5-3.0" high temp rubber elbow fitted in the gap nicely. The GT2X entry is not 2.5" so I used the ATP adapter collar (machined collar with seal and grub screw to secure it on the outside), then the 2.5-3.0" elbow was a good, tight fit. Looking down into the pipe it looks like:
Not ideal but offers alot more airflow and room compared to the 225 hose. The elbow is this one:
http://www.atpturbo.com/Merchant2/m...oduct_Code=ATP-SIL-240&Category_Code=SIL-90EL
The rest was easy, 3" hardpipe fits in the rest of the way up, it's a little short so I used a 76mm alloy joiner to lengthen it. As you can see, it comes up here and from there it's just a silicone coupler onto the ATP hardpipe bend towards the MAF.
When you compare it to the 225 hose the bottom half is at least an inch wider right down to the turbo, my butt dyno tells me it has really helped too, the Astra VXR I recently destroyed is testament to that!
Here's some pics of it all fitted and complete:
http://www.rd20vturbo.pwp.blueyonder.co.uk/images/engine/hp1.jpg
http://www.rd20vturbo.pwp.blueyonder.co.uk/images/engine/hp2.jpg
http://www.rd20vturbo.pwp.blueyonder.co.uk/images/engine/hp3.jpg
ATP told me that the 225 hose was too restrictive and that a larger intake would yield better results, I now believe them 100%, so if you're getting a GT2X don't bother with the 225 hose. So in summary the bits I used to get this inlet together were:
ATP GT2X inlet collar adapter
ATP 3" inlet kit
3" alloy hose joiner
Steel mounting plate with 4 holes to move shifter bracket away from turbo.
I bought everything directly from ATP, the 3" inlet kit cost me £180 including shipping from the USA and arrived in 3 days - my tuner wanted £300 for the same kit!!!
Hope this info and pics helps.
