GT2x fitted - major lag !!
Cupra_Jeff
126
Kent
I reset the ECU and did the TBA and although it does feel pretty damn rapid it still doesn't appear to be hit full boost till around 4,500rpm. Anyone have any ideas ??
I thought all the N75 was there for was to control the boost and wouldn't affect the spool up as i persume 100% means the wastegate is closed ? is that right ?
Correct, however the ECU might think it's jamming the WG shut but in reality it might not be. One way to test would be to bypass the N75 and carefully take it for a spin. If the car makes boost quickly then you know you've got a boost control problem. Just be carefull not to get carried away as you'll not really have boost limit.
Cupra_Jeff
126
Kent
I still dont think it it will much good on N75, when i plug mine in the boost pressure is all over the place and the car runs like a bag of crap.
Manual boost controller works ok, but apexi is the bollocks, mine now runs 1.4 BAR and pulls very very hard hold ing 1.4 BAR to the redline.
Matt if you have a manual boost controller does this replace the N75 totally ? how hard is an Apexi to wire up ?
Cupra_Jeff
126
Kent
How do i go about bypassing the N75 mate ?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
use a t piece on the 3 vac hoses...
best leave it plugged in though would have thought...otherwise it'll prob go into gimp mode, then again if the n75 is bypassed the ecu might not have the ability to do so anyway
Cupra_Jeff
126
Kent
This is an inlet restriction on the air inlet side of the turbo, or an issue with actuator rod.
My money is on inlet restriction.
But i've got the 3" ATP inlet and 3" MAF, so I'd hope not..... maybe its the shitty filter that came with the kit ?? would a bad filter really make that much difference ?
Wilko
Badge snob
Check all the fittings onto the turbo inlet side, A small inlet restriction can make a massive difference, Not necessarily the filter, but the pipe work.
Also check the wastegate is shut on the actuator rod. Pull on the actuator rod and see if you can hear the flapper clacking on the housing. Then check the vac piping to the acuator.
Only other thing could be exhaust leak pre turbo,fecked n75, or massive post turbo exhaust restriction.
A manual boost controller vs an n75 at 100%DC will not aid spool 1 bit, unless n75 is screwed.
Cupra_Jeff
126
Kent
ok mate nice one, will check that lot tomorrow when it light
NoFriegue
I got the same problem as you. I get full boost at 4000 rpms.
And I'm using a EBC to try and hold the boost but that doesn't work.
Here's the log.
Code:
	Engine Speed	Engine Load	Charge Pressure	Charge Pressure		Engine Speed	Engine Load	Injection	Intake Air Mass		Lambda Sensor	Lambda Sensor
TIME			(specified Value)	(actual Value)	TIME			Timing		TIME	Current Value	Specified Value
STAMP	 /min	 %	 mbar	 mbar	STAMP	 /min	 %	 ms	 g/s	STAMP
0.01	920	56.4	970.0	870.0	0.30	960	59.4	5.78	11.36	0.60	1.000	1.000
0.89	1040	60.2	1020.0	870.0	1.21	1080	60.9	5.44	13.14	1.51	0.969	1.000
1.81	1200	62.4	1290.0	890.0	2.11	1240	63.2	5.44	15.64	2.41	0.984	1.000
2.72	1320	64.7	1390.0	900.0	3.02	1400	65.4	5.78	17.97	3.32	0.992	0.961
3.62	1480	67.7	1470.0	920.0	3.92	1560	68.4	6.12	20.97	4.22	0.922	0.953
4.53	1640	69.2	1760.0	950.0	4.83	1720	69.2	6.12	23.08	5.13	0.969	0.953
5.43	1840	70.7	1990.0	980.0	5.73	1920	70.7	6.46	26.19	6.02	0.945	0.953
6.34	2040	72.9	2130.0	1020.0	6.64	2120	75.2	6.80	31.39	6.94	0.938	0.953
7.24	2280	80.5	2190.0	1090.0	7.54	2360	83.5	7.48	38.97	7.84	0.969	0.953
8.15	2520	85.0	2240.0	1170.0	8.45	2600	85.7	7.48	43.58	8.75	0.945	0.953
9.05	2760	89.5	2300.0	1230.0	9.35	2880	90.2	8.16	50.64	9.66	0.945	0.953
9.96	3080	94.7	2330.0	1290.0	10.26	3160	98.5	8.84	61.17	10.56	0.914	0.953
10.86	3360	108.3	2300.0	1450.0	11.16	3480	115.0	9.86	79.89	11.46	0.938	0.953
11.77	3760	130.8	2320.0	1720.0	12.07	3880	142.1	12.24	109.94	12.37	0.945	0.938
12.67	4160	155.6	2320.0	2020.0	12.97	4320	157.9	15.98	130.83	13.28	0.797	0.821
13.58	4600	155.6	2270.0	2040.0	13.88	4720	153.4	15.30	136.89	14.18	0.821	0.828
14.48	5040	144.4	2240.0	1980.0	14.78	5200	143.6	14.28	140.72	15.10	0.821	0.828
15.39	5440	141.4	2250.0	1880.0	15.69	5560	138.3	13.26	146.78	15.99	0.821	0.828
16.29	5800	134.6	2230.0	1810.0	16.61	5920	133.1	13.26	150.44	16.91	0.828	0.828
17.21	6160	129.3	2170.0	1810.0	17.50	6280	127.1	12.24	152.39	17.80	0.828	0.828
18.10	6440	124.8	2130.0	1690.0	18.42	6560	124.1	12.24	150.92	18.71	0.813	0.961
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
if you want to eliminate the control side of things, clamp off the pipe to the actuator and drive "carefully" and see if it spools any faster or higher.
Be careful and steady on the throttle when trying this as you have no boost control at all.
Can show some hardware limitations this way
Cupra_Jeff
126
Kent
mines got a custom remap a wideband a/f and EGT meter, seems fine a/f ratio wise and timing looks fine with no more than the occasional 3 for CF.
Boost request has been kept on the conservative side at the moment but can be upped when its all running right.
I've checked all the connections and the intake with no obvious obstructions. Going to trying running it with out an N75 tonight to see if this makes any difference.
I'm convinced it is a problem with wastegate flap not closing fully meaning the turbo is not making good boost until higher up the rev range.
Cupra_Jeff
126
Kent
Any news mate?
I had a play with the actuator rod and managed to get it a bit better (full boost by approx 4,700rpm) still not really happy so i removed and refitted the 3" inlet to check for leaks or blockages (of which I could find none)
So i'm a bit stuck now, I'm gonna take it back to the guy that fitted and mapped it for him to check it all over for me...
I also e-mailed ATP and they reckon it may be the d/p and cat which is too restrictive... i'm not sure that this is true as there must be others with the Milltek d/p and cat which have full boost 1000 rpm earlier
Might have to try a decat pipe and see if i have any luck with this
