I would love to make my cupra TDI AWD
Keep up the good work mate. I really want to see the finished car
Thanks.... i can't wait myself
I think the spolier will look ok in the end, just need to look at the bigger picture
Keep it up and welcome to the slow progress club too
Cheers Mate, hope it looks ok - but I'm sure it will good with the theme I'm looking for.
Looks awesome Graham. Been keeping a very close eye on this and cannot wait too see the end result!
Congrats on the baby mate!
Thanks for the kind words
I quite like the look of the spoiler.....didn't think i would but i do, well done again on the effort to avoid the perspex screen.
Cheers Phil, Thanks for the comments.
Smallish update ---------------
So just finished for the day, far too cold to be working outside all day.
So i wanted to angle the spoiler mount closer to the back window so i set about altering the angle of the mount.
I started by cutting the mount just where it came through the boot opening - i then bent it towards the back window until the angle looked better ( i was after a angle nearly vertical with the boot)
Took several attempts to get it looking right.
After that i decided to remove the main uprights from the mounting horizontal pieces, i did this so i could ensure the angle was exactly the same between the two uprights.
Once i was happy the angles were the same i welded up the cuts i just made and the cut outs where the horizontal brace was -
I then ground all the welds flat and remounted the lower horizontal brace back on by tack welding it -
I am going to weld up the holes where the uprights come through the boot, just need to get some metal ordered.
Tried it on and it looks instantly better -
Bolted in using the lower brace -
So i bolted the top brace into place then had a measure up and made some plates to join the upper brace to the mount.
All tacked up and bolted back in -
So after that i decided to see what the spoiler would sit like a bit closer to the window (more like the original Supercopa)
Just cabled tied on again - Obviously the angle of the spoiler will be set properly when i make the brackets for the top.
Shots from up high -
Think it definitely looks better not sitting as far back
After that i decided to start fitting the clips to hold on the side skirts.... i haven't ordered enough of the clips so could only put 4 on. I just drilled and self tapered the brackets on -
Called it a day after that, i'm frozen to the bone..... gonna have a snooze and then set off to drive down south 400 miles !!!!
Keep the comments coming, thanks and so long for now
