Glow plug/ engine management light - no fault code
Sep 12, 2022
Hey everyone. New to posting on the forum, I have seen there have been a lot of threads regarding glow plug warning light. Need some advice as seem to be having a different issue.
So its 1.6TDI with 155,000km on, been maintained well. Have had glow plug come on and off over last 6 months and now its pretty much every journey and the engine management light has now joined it.
Had a P0299 code which was then solved with changing the N75 valve. Now I have no codes showing either on a normal OBD reader or by seat garage itself but still have the warning lights and limp mode most of the time. Seat garage has suggested replacing turbo which seems like a very costly option.
From what I understand could try EGR valve or just changing glow plugs but I thought I would get a fault code for those issues. Seems like they are just suggesting trying to swap bits and hoping for the best!
You guys any opinion on what to try first?
Sham
75
Update: bought a basic fault reader and the PO299 fault code as re-appeared
Hi
I have a fault code of P029900 is that the same as yours ?? If so how much was the n75 valve change ??
