Getting to the ecu
speedsix
Leon Cupra R 225
Oct 30, 2004
825
I need to check the connection between the throttle pedal sensors and the ecu as I'm getting intermittent 'implausible signal' errors logged for the sensors in the accelerator. This causes the EPC light to come on and the car to go into a limp mode.
It's under the plastic near the passenger wiper right? Any tips getting to it and also finding the right connection for the pedal sensors?
Also, I haven't had a good look at the pedals, are the sensors on the clutch pedal and are there any connections that could be lose that end?
I'm hoping to god there's no corrosion of anythign expensive at the ecu end.
Any advice welcome
Dom
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
To get at the ECU:
Remove wiper arms.
Remove the rubber sealing strip running accross the 'front' of the plastic valance panel.
Pull the top lip of the valance panel upwards from the bottom of the windscreen (ie in a direction at 90 degrees from the windscreen surface) working from the outer corners.
Explained another way,
A lip in the back of the plastic valance
clips in a metal groove at the base of the windscreen
ECU is central under the windscreen.
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
took mine off a while back (easy to do) but has anyone found that the little plastic trays fall off really easily? Also had problems with the valance panel lifting on the drivers side when i put it back on (its marked now cos the wiper catches it). Going to get a new panel but worried that its the little groove that the panel goes into (attached to the wiindscreen) that is not holding the panel correctly and will have to remove the screen to replace that (i think?). Just wondered if anyone has has this issue and if so how did you fix it?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I've had my valance off several times and have no issues with it sealing the windscreen perfectly. I guess you must have damaged your valance panel.
Yes, the gutter trays fall off easily weithout the valance properly in place.
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Took mines of a few times, to feed the boost line through gomit and seal it. Is it normal to be agap between the screen and the valance panel? Pushed it but it still dosnt stick.
what if what enters it as dribbles down the windscreen?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
There shouldn't be a gap. When the valance is fitted properly, its top edge is clamped down tight across the screen.
Big_daddy
Oct 20, 2006
3,930
Brummy
Take it off and see if there's anything in the metal channel that's preventing the valance bead seating properly. :)
Its raining, getting abit worse (dam the weather!!) Tried pushing it down and it just pops up.
See pic
My main concern is would it be ok for abit? as its raining and cant do it as i have strip the wipers and pollen filter cover. Will it get into any thing such as the ecu?
Cheers DPJ ;)
Big_daddy
Oct 20, 2006
3,930
Brummy
I haven't got a garage either. I have a £14 pergola. :D (It's a b*gger erecting it when it's windy!)
can i borrow it :lol:
Just went out to do it, its a slight drizzle but i was under the bonnet. 1st attemp i couldnt do it, :censored: 2nd attemp go the screw driver out, then forced it down. Only herd 1 click on each side thats it, the the driver side when down, so im ok. Any more pressure i would have went through the windscreen.
What you think?
can i ask what are those black plastic clips on each of bonnet hinge Keep coming off, [:@]
dainott2105
Nov 4, 2006
685
swansea
so you heard a clipping noise when you pushed it down!! I dont get that noise so does anyone know if there is a clip there somewhere that keeps it down and if it can be replaced?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
What you think?
:thumbup: That looks more like it. I'm not quite with you on the clips.:confused:
No, there's no clip for the valance panel, the bead is a push fit into the channel all the way along.
speedsix
Leon Cupra R 225
Oct 30, 2004
825
Update: needs a new throttle pedal £120. I'm a bit dubious as I didn't see any sensors on the throttle pedal itself.
speedsix
Leon Cupra R 225
Oct 30, 2004
825
I thought I read somewhere that it was on the clutch pedal. What are the multiplugs on the brake and clutch pedal?
