Getting to the ecu
FishmanUK
18psi goodness
Sep 3, 2006
45
Pretty sure I am getting the same error now. OBDII diagnostics by RAC showed 'implausible signal' on accelerator pedal sensor.
EPC comes on after a random period of time and it goes into limp. After a power off and on it usually is sorted but sometimes comes back quickly and brings on the diagnostic/pollution light. Will Vagcom when I bring my laptop home from work.
Is it just a case if a new pedal or does it need syncing with the ECU ?
If it does need some ECU work presumably by map will be OK ?
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Might want to read this thread http://www.seatcupra.net/forums/showthread.php?t=258642
FishmanUK
18psi goodness
Sep 3, 2006
45
Cleared the fault that was logged. Left the exact wording on my laptop but copied from elsewhere this is the fault that was logged
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
Did some logs on group 62 (did group 60 also)
Throttle pos/ sender 2 TPS is 2 or very close at all times. I believe this means it is working OK. Throttle sens 1 doesnt seem to correlate to throttle pos that well but throt sens 1 + throt sens 2 ~100
Anyone confirm these are typical and I really just have an intermittent problem ?
Code:
Group C:	'062
	Throt Sens 1	Throt Sens 2	Throttle Pos	Sender 2 TPS
TIME	3-93%	97-3%	12-97%	4-49%
STAMP	 %	 %	 %	 %
0.4	14.8	84.4	15.6	7.8
1.81	14.8	84.4	15.6	7.8
3.1	12.9	86.3	20.7	10.2
4.42	16	83.2	25.4	12.5
5.73	21.1	78.5	28.1	13.7
6.93	25.8	73.8	30.5	14.8
8.24	30.5	68.8	32.8	16.4
9.45	36.3	62.9	36.3	18
10.75	42.2	57.4	39.5	19.5
12.06	48.4	51.2	43.8	21.9
13.28	52	47.7	46.1	22.7
14.57	55.9	43.8	48.8	24.2
15.89	60.2	39.5	52	25.8
17.2	67.6	32	57.4	28.5
18.49	71.9	27.7	60.5	30.1
19.71	77	22.7	64.5	31.6
20.91	82.4	16.8	68	33.6
22.22	85.5	14.1	79.7	39.1
23.44	85.9	13.7	82	40.6
24.73	85.5	14.1	82.4	40.6
25.95	85.5	14.1	82.4	40.6
27.15	85.5	14.1	82.4	40.6
28.36	85.5	14.1	82.4	40.6
29.77	85.5	14.1	82.4	40.6
31.07	85.5	14.1	82.4	40.6
32.38	85.5	14.1	81.3	40.2
33.59	84.8	14.8	69.1	34
34.79	74.2	25.4	61.7	30.5
36.2	64.8	34.8	55.1	27.3
37.4	57.8	41.8	50	25
38.62	49.2	50.4	43.4	21.5
39.82	35.2	64.1	35.2	17.6
41.13	14.8	84.4	15.6	7.8
42.34	14.8	84.4	15.6	7.8
43.54	14.8	84.4	15.6	7.8
44.86	14.8	84.4	15.6	7.8
46.15	14.8	84.4	15.6	7.8
47.46	14.8	84.4	15.6	7.8
